Gauges installed!!!
Gauges installed!!!
I've finally installed my 2 primary gauges, my Turbo and EGT.
I have some pictures up on webshot while the ones here are being approved.
Gauges:
Piller Pod... made to fit
Another: different angle
The tranny gauge is next, but I still need to research some good place to put it.
It was pretty easy overall. The boost was a snap and the EGT was manageable. I couldn't have done it without looking at everyones pics though. My AutoMeter instructions didn't say anything about drilling into the manifold and tapping
Probe Installed
I took her for a run, and my numbers looked like this:
20 mph - Boost 0; EGT 400
WOT
40 mph - Boost 15; EGT climbing to 900
continued WOT
60 mph - Boost drops to 10 between gears and climbs back to 15; EGT 1000
continued WOT
80 mph - Boost begins to drop as I slow down; EGT 1100
The EGT bounces around more than I expected. As I let off the throttle at 70 mph she settles to around 900. In the city, she'll hover around 800 and at stop she will settle to 400. That kinda suprised me, but I guess it makes sense. I was expecting more constant numbers.
Gauges:
Probe Installed
WOT
continued WOT
continued WOT
Do I have room to turn the fuel pump up? I expect I will get more EGT, but how much more with each turn of the pump?
Man, I'm ready for more power!!!
well do you drive it to the floor ever single time without letting off? then crank her up. because i belive 1250 is cummins temp for running @15min or so at a time.
Patron Saint of 1st gens
Yup....1200*F (allow 50'ish *F for guage error) all day...if you run at the max duty cycle of 1200*F you need to keep an eye on the water temps....after a while all that iron and rad start to get "heat saturated" and eventually the rad starts to loose ground...then, you just gotta ease up.
Cummins runs these things at max load/max throttle holding a sustained 1200*F for hundreds of hours to test them. They just keep feeding it fuel and finally they tear it down and go looking for foobar's....
pb....
pb....
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
estesbubba
07-18-2006 04:35 PM
AggiePhil
01-30-2005 01:15 PM
