gauges
Old May 14, 2008 | 10:19 PM
dieseljoe92's Avatar
gauges
i found a three gauge kit that was cheap and i am going to put two gauges on the piller and was woundering if anyone makes a steering coloum pod for our trucks
Old May 14, 2008 | 10:26 PM
Richie O's Avatar
366 Spring Chicken
Read this link
https://www.dieseltruckresource.com/...d.php?t=203792
Trooperthorn's Avatar
This is for a 2 gen., but the guys say it fits ours. Someone will confirm or argue.
http://www.genosgarage.com/prodinfo....er=GM-DG-15012
Old May 14, 2008 | 10:34 PM
Here is a link to one being used for a tach.
https://www.dieseltruckresource.com/d...d.php?t=173561
Old May 16, 2008 | 11:09 AM
ofcmarc's Avatar
Fits great.
Only fits tilt columns.
Old May 16, 2008 | 10:07 PM
dieselweaver04's Avatar
what about tilt colume automatic
Old May 17, 2008 | 12:09 PM
ofcmarc's Avatar
Auto/ manual dosen't matter.
Old May 17, 2008 | 01:42 PM
Originally Posted by ofcmarc
Fits great.
Well...true and not true..the tilt hole is there but i put it in our non tilt truck and the hole is just there, with no lever...put a switch in that hole or something.....
Old May 17, 2008 | 02:50 PM
bradshaw106's Avatar
what tach is that?
Old May 17, 2008 | 03:35 PM
ofcmarc's Avatar
Originally Posted by bradshaw106
what tach is that?
Auto meter Z-series 5k tach (2 1/16th"). It reads at about 1/2 speed cause it isn't a diesel Tach and for some reason the tach signal from the PCM isn't good enough for the tach.... It's on my list of things to figure out.
Old May 17, 2008 | 05:35 PM
Richie O's Avatar
366 Spring Chicken
I got the cup mount for mine. I have the old colume and I sheet metal screwed it. I like it and can still see thhe speedo.
Old May 17, 2008 | 08:14 PM
does yours read accurate ?
Old May 17, 2008 | 09:44 PM
Richie O's Avatar
366 Spring Chicken
yes but I have the magnetic pick up on the balencer. My 89 has no provisions for "plug in " as I have no pcm.
Old May 17, 2008 | 11:58 PM
Philip's Avatar
The Dodge tach signal is only a 5 volt feed voltage. Your lucky the tach will even read that low of voltage. I have one of those tach's and it will not read my PCM signal.
Your 5 volt power feed from the PCM might be a little loose and is giving a higher voltage.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
estesbubba
Jul 18, 2006 04:35 PM
AggiePhil
Jan 30, 2005 01:15 PM
