gas cluster same as diesel?? help
Old Apr 12, 2008 | 02:25 PM
We just parted out a 1992 D250 gas 318 truck.Had a good working cluster in it so i pulled.I have a diesel cluster here so i compared and hookups are the same but internally IDK??? does anyone know if this gas cluster will fit 91-93 diesel????
Old Apr 12, 2008 | 02:42 PM
DISTURBED's Avatar
I dont know if they'll fit but your gauges will be off such as oil pressure and temp
Old Apr 12, 2008 | 04:16 PM
haloman's Avatar
They are the same. I have a gasser cluster in my 91'
Old Apr 12, 2008 | 04:51 PM
haloman, you saying that--- oil pressure,battery,fuel level,water temp all work??? WOW
Old Apr 12, 2008 | 05:25 PM
haloman's Avatar
yea all work exactly the same it doesnt take long to swap one out and see for yourself
Old Apr 12, 2008 | 07:43 PM
scottmn1's Avatar
40 lbs of oil pressure from a Cummins is the same as 40 lbs of oil pressure from a 318, and the same from the temperature sending unit. I see no reason the gauges would not work.
Old Apr 12, 2008 | 09:55 PM
Fred Swanson's Avatar
yeah, they work, I kept the 93 RamCharger gauge cluster in my Cummins conversion, and they all worked.
Old Apr 13, 2008 | 08:34 AM
AUGIE DOG's Avatar
Gasser Guage Cluster
WOW AM I EXCITED TO HEAR THE GASSER CLUSTER WILL WORK!! I STILL HAVE MINE AFTER CONVERSION WAS COMPLETED. I SERIOUSLY THOUGHT OF SELLING IT. NOW FOR MY QUESTION???? I STILL HAVE THE ORIGINAL 4:10 REAR END IN MY TRUCK SO IF I PUT GASSER CLUSTER BACK IN MY SPEEDO SHOULD BE ACCURATE AS BEFORE?? NOW I AM GETTING READY TO SWAP DONOR REAR END WHICH IS I BELIEVE A 3:54 IS IT SAFE TO ASSUME THAT MY SPEEDO WILL BE OFF SOMEWHAT??? I ALSO PUT A 47rh IN TO REPLACE THE A-518 WILL THIS HAVE AN AFFECT ON MY SPEEDO?? I WILL CONTINUE TO WATCH THIS THREAD.IT WOULD BE NICE IF SOMEONE DOING A CONVERSION WOULD DOCUMENT SOME OF THIS STUFF FOR GUYS GETTING READY TO DO A CONVERSION. I KNOW THAT A THREAD WAS CREATED JUST FOR CONVERSIONS BUT TIPS LIKE THE GUAGE CLUSTER AND USING THE GASSER FUEL TANK ARE NEED TO KNOW ITEMS TO HELP THE CONVERSION GO SMOOTHLY........ ANYONE HAVE SUGGESTIONS? AUGIE DOG
Old Apr 13, 2008 | 07:12 PM
AUGIE DOG----the gears in the cluster dont match up to the gears in the rear at all...no specific cluster for specific gears....i took a 3.54 cluster and put in 3.07 truck and it works same. no difference
Old Apr 13, 2008 | 10:02 PM
The determining factor is the speedo gear in the tcase and the little black reduction gear on the 205 tcase.
Old Apr 14, 2008 | 10:13 AM
carl48's Avatar
i think our 91 ,92,and 93's had a gear box on the transfer case to correct for tire size and rear end ratio's i will look. may be someone will tune in
J Lent
60
Nov 3, 2009 09:14 PM
TXBobcat
Sep 14, 2008 03:45 PM
CaledoniaOutlaw
Jan 30, 2008 01:32 PM
Need95-00CTD
Jan 14, 2008 09:07 PM
WideOpenThrottl
Jul 27, 2007 08:01 PM
