G56 2wd into a W250
Old Oct 14, 2014 | 11:06 AM
Philip's Avatar
A set of bearings and reset preloads might be all it needs.
If you look at the trans. Grab the output shaft. If you can move it in and out. That tells you the problem. You can pull the PTO covers and check countershaft play also. You need inverted torx sockets to remove any bolts in the case.
If you find the output shaft has up and down play. That is a good way to get the price down lower.
Old Oct 14, 2014 | 01:57 PM
Thanks for the advice on what to check!
His asking price is already really low...but if I could get it for a bit cheaper I would not complain.
I've really been thinking about this as a future upgrade for the crewcab, but I really should be spending that money on my rear diff rebuild first.
Old Oct 15, 2014 | 08:46 AM
mknittle's Avatar
I really shouldn't be reading threads like this.
Old Oct 15, 2014 | 01:05 PM
Yeah me neither........
Old Oct 15, 2014 | 02:00 PM
Philip's Avatar
You know you want to. Don't fight it.
Old Oct 15, 2014 | 04:50 PM
Alec's Avatar
Why swap in a G56 when you could swap in an FSO? That's aimed right at you, Mark. And maybe Brian, too, but 4x4 is a little tougher.
Sorry for the Hijack.
Old Oct 15, 2014 | 08:40 PM
FSO? You making reference to a roadranger type transmission....10, 13 speed?
Old Oct 15, 2014 | 08:45 PM
Philip's Avatar
Why a FSO. The gear spread on them isn't much better than the Dodge selection is. A SAE #3 adapter has firewall and floor board issues. The trans will have floor issues. The only thing going for them they are cheap. Certain models of FSO's have issues also.
Old Oct 15, 2014 | 09:08 PM
Philip's Avatar
FSO is the 5/6 speed poor geared trans used in class 5 trucks.
The big trans are normaly RTO's and so on.
http://www.eaton.com/EN/EatonCom/Tru...ions/index.htm
Old Oct 15, 2014 | 09:51 PM
dan123dbl's Avatar
I've been eyeing up the same transmission Thrashingcows Very tempting for the price. I'm thinking I might go the gearsplitter way instead of swapping in a g56 though.
Old Oct 15, 2014 | 10:01 PM
Yeah I have been trying to convince myself I need it as well.... But I have decided I need to redo my front, and possibly the front diffs first.
But I will probably go with a GV unit as well...eventually.
12V_shooter25
Jun 10, 2013 11:22 PM
iskone
Sep 17, 2009 03:29 PM
Bobcat698
Apr 1, 2007 10:26 PM
TexasHardcore
Aug 29, 2004 12:20 AM
