full fuel pin leak
Old Dec 10, 2007 | 07:30 PM
93beater's Avatar
Thumbs down full fuel pin leak
turned the truck on earlyer when cold and there was a good dripping leak that looked to be commin from the full fuel screw, i took it into the shop it needed a couple little things like the brake and abs lights stayed on needed new battery terminals and needed the lift pump and fuel lines checked and a couple other small things, so hopefully ill get it back soon, has anyone else had a leak commin from there?
Old Dec 10, 2007 | 08:42 PM
1stGen545's Avatar
there is a o-ring on it.
Old Dec 10, 2007 | 09:21 PM
90firstgen's Avatar
Take it out and examine that oring.
Old Dec 10, 2007 | 09:55 PM
93beater's Avatar
well thanks for the info ill take it to the fellas shop he is a good buddy of mine and ill let him know, my truck was really hard to start in the mornings, i had to get out and prime the lift pump, seemed like air was gettin in the fuel, do you think this could be the reasson?
Old Dec 10, 2007 | 10:57 PM
90firstgen's Avatar
Most definately. That is if you don't have any other air/fuel leaks.
Old Dec 11, 2007 | 03:55 PM
1stGen545's Avatar
Mine did that with the pump head o-ring leaking and would drain the pump.
Old Dec 11, 2007 | 04:16 PM
93beater's Avatar
well im glad to know i found my problem, i shoudl have my truck back within the next couple days! thanks guys
gaberichison
Dec 21, 2014 12:21 PM
Cowboy_Customs
Oct 18, 2011 01:46 AM
Blowndodge
May 19, 2011 09:43 AM
1985cucv
Nov 8, 2008 10:32 AM
bigragu
Oct 17, 2005 04:07 PM
