Fuel Tank Capacity
Old Feb 26, 2005 | 03:14 PM
SmokinFive9 4x4's Avatar
Winr, what did you use a selector valve when you added the aft tank? I dunno how the ford's work, but I'd bet you could adapt it. But I think it's 200 bucks if memory serves me from when I priced one about a year and a half ago.
Old Feb 26, 2005 | 03:30 PM
Winr's Avatar
Nappa sells them. I dont remember the application (I think it was univesial). I may have the part # for the selector but I'm not sure, I'll look.
I used a 3 position switch on the dash for tank and gauge selection.
Old Feb 26, 2005 | 05:05 PM
Redleg's Avatar
Originally posted by edwinsmith
Well, if I still have at least 5 gallons left when the low fuel light comes on, I should be well able to drive the 30 miles to Copan where the cheap fuel is. I was just going by the guage which showed less than that. I guess my light is more accurate than my guage.
The idea about putting another tank where the spare is sounds good. A lot of car tanks would probably fit there very well. Plenty of room in the bed for the spare. (It's a PITA to get it from out under anyway.)
Edwin
Wasn't bringing up any problems with cooling the pump, just saying if you have 5 gallons when you shut down, the next day you won't have 5 when it cools. How many gallons to prevent the pick-up from sucking air? How many more if you don't park level? Just some food for thought, I've come into work late a couple times over the years, and had to coast to a level spot and crack injectors after my shift. Then hit the nearest, expensive gas station.
Old Feb 26, 2005 | 06:13 PM
edwinsmith's Avatar
I had a Mitsubishi Montero once that didn't have a working gas gauge. I carried a can of gas so when I ran out I put in the can and started looking for a station. I've had to re-prime my diesel once when I changed the fuel filter. It wasn't so bad but took some time to get all the air worked out. (10 minutes) I couldn't seem to get that lever on the lift pump to work though. I didn't know about the valve to open to let the air out though so next time it'll be easier.
Edwin
Old Feb 27, 2005 | 04:56 PM
vavtx's Avatar
Smokinfive 9 4X4. JcWhitney sells them for about 50.00. I just replaced mine needlessly. It turned out to be a bad wire. It comes with the toggle switch and wiring connector. You can use generic fuel hoses and clamps to splice into your existing fuel lines. You will need the 6 port valve. Pretty easy to install and comes with instructions. It is the same one NAPA sells...a Pollak.
Old Feb 27, 2005 | 05:32 PM
Good to know for future reference. Thanks
robox
Aug 18, 2007 05:36 PM
jj3500
19
Sep 12, 2006 11:50 AM
ddestruel
Mar 26, 2006 01:54 AM
2002cumTRBODSL
Dec 23, 2005 11:01 PM
