Fuel return line leak
Old Feb 28, 2011 | 11:53 PM
raggmann's Avatar
It appears my truck has developed a leak on the fuel return line near the rear of the engine where the line drops from the "T" down the left side of the block.
It's washing the side of the block around the lift pump.
It's not the lift pump as the moisture is above the pump mount. The line on the bottom of the T itself is pretty crusty looking-I steam the engine every 2nd time I wash the truck so it's somewhat obvious where it's coming from.
I'd think nothing of tearing it apart and fixing it except it's -33C with the wind and my truck doesn't fit in the garage so pulling the line off just to have a look is out of the question.
I'm sure there was a thread or some comment about fixing this issue BUT latley when I try to search anything on the site it comes up with:
Fatal error: Allowed memory size of 50331648 bytes exhausted (tried to allocate 35 bytes) in /opt/www/html/dev/search.php on line 1155
I don't know what's going on there but does anyone have a link to or remeber the repair?
Thanks,
Old Mar 1, 2011 | 10:05 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Thanks,
The problem you are having with the search engine is caused by TOO MUCH information, you are overloading the server because your search covers too much territory.
To get around this, use the advanced search box and then type your search info into the little Google box you find in there, then Google can use their vast resources to search our vast resources without overloading our server like that
There is SO much information stored here that if your search is generic and not extremely specific, it overloads the server.
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
big jimmy
May 12, 2006 05:44 AM
Twogun
Aug 17, 2005 08:47 PM
