fuel pressure
fuel pressure
This Guy I no might have taken out his injection pump but idk what the fuel pressure of the pump at an idle with a stock lift pump. The trucks a 93
Thanks again Mike
Thanks again Mike
Pump, pump, and another pump; I think you are asking what is the normal pressure of the stock diaphragm lift-pump at idle.
If so, a healthy pump will register between 4- and 7-PSI.
I have seen them as low as 2-PSI.
BUT, you can have a completely dead diaphragm lift-pump and the truck run the same; in fact, there are many of these old trucks that have been running around on a dead lift-pump and the driver none the wiser.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
