fuel pressure
Old Mar 9, 2009 | 06:25 PM
comptz's Avatar
fuel pressure
I just got my fuel pressure guage hooked up and i am only getting 2-4psi after the filter. Is my pump going bad or could my filter be blocking that much pressure?
Old Mar 9, 2009 | 07:01 PM
peobryant's Avatar
Are you running the stock lift pump? If you are, that sounds about right, unfortunately.
Old Mar 9, 2009 | 07:03 PM
comptz's Avatar
yes i am running the lift pump it came off of the line with.
Old Mar 9, 2009 | 07:36 PM
peobryant's Avatar
Is it 2-4psi at WOT?
Old Mar 9, 2009 | 07:47 PM
comptz's Avatar
no, this is at idleing.
Old Mar 10, 2009 | 04:33 AM
KRB's Avatar
KRB
Tell us about your install. What, how & where .
Old Mar 10, 2009 | 11:22 AM
Ace's Avatar
Ace
2-4 at idle is a little low. You either need a new filter or have a tired pump.
Old Mar 10, 2009 | 03:36 PM
comptz's Avatar
I bought the tapped 1/8'' banjo bolt from autometer to plumb my electrical sending unit in after the filter for the meantime the sending unit is mounted directly in the banjo bolt, i am going to get a grease hose soon to take the vibration away. Then i have my 30psi glowshift guage in the dash. All in all it was an easy install.
Old Mar 10, 2009 | 03:40 PM
Ace's Avatar
Ace
Running a 30psi gauge with a stock pump might read 2-4 and actually be anything from 2-7 on the low end of the scale. Analog gauges are most accurate around the middle of their sweep, with some degree of error at either end.
Old Mar 10, 2009 | 03:43 PM
comptz's Avatar
the guage also bounces around alot at idle too.
Old Mar 11, 2009 | 04:39 AM
KRB's Avatar
KRB
So for a VE and OEM lift pump, what capacity gauge would be best? So that the reading would be in the middle? 20PSI?
Old Mar 11, 2009 | 05:28 AM
Ace's Avatar
Ace
15 would be appropriate with a stock pump. I never saw a 20.
Old Mar 11, 2009 | 11:37 AM
rcurrier44's Avatar
My brand new 91.5 lift pump (from cummins) will do 9psi when cold, 3psi @ WOT (relitivly stock motor/pump not turned up), 5psi-6psi or so warm & idle.
EDIT: I use a 15psi manual guage...
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
