Fuel pressure ???
Old Jan 5, 2009 | 07:26 PM
Onemoparnut's Avatar
Fuel pressure ???
I want to get a fuel pressure gauge next. How much fuel pressure do these trucks have? Is a 30 psi gauge enough?
Old Jan 5, 2009 | 07:31 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
A 30 psi guage will be plenty
Old Jan 5, 2009 | 07:36 PM
1985cucv's Avatar
ours have 7-9 with a stock lift pump but dont quote me on that the ve runs best with 15 i believe
Old Jan 5, 2009 | 07:40 PM
93John's Avatar
15 PSI is the max and then the front seal of the IP can be pushed out.
Old Jan 5, 2009 | 08:26 PM
oilburner 5.9's Avatar
fuel pressure
well i also have a question, how much pressure does the piston lift pump put out?
Old Jan 5, 2009 | 08:45 PM
DNRCustoms's Avatar
the low pressure one found in the sticky i belive puts out 14-15psi... It is the popular upgrade...
Old Jan 5, 2009 | 10:11 PM
Thanks alot guys..
Old Jan 6, 2009 | 07:00 AM
Ace's Avatar
Ace
If your going to monitor a pressure that will never do anything but go down, it's not a bad idea to use a gauge with a max reading near that pressure. Then you're using the needle's full sweep.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
