Fuel Pressure
Fuel Pressure
How much fuel pressure should I have?
I am replacing my lift pump this weekend.
I seem to have lost a lot of power and it is leaking down my block.
Anyone know the specs on the OEM pump and whom is it made by?
I can get either of 2 pumps from the Auto Parts Carter or an Airtex both with a lifetime warranty for $70.00.
I checked the specs on the pumps and they list it as 6.0 -7.5 PSI static but that doesn't make much sense.
Thanks Jim
Thanks Jim
Cummins says minimum acceptable is 3 psi at idle. A healthy stock lift pump will put out at least 7 psi. Factory is a Carter AFAIK. I used a Delphi for about a year with good results before I upgraded to the piston pump. I got it from usdieselparts.com.
edit: direct link to the pump you want
http://www.usdieselparts.com/moreinf...name/Feed_Pump
The price is lower than when I bought mine a few years ago.
dodgeguy71
17
Jan 19, 2012 12:52 AM
bigragu
Jan 24, 2006 11:16 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
