Fuel preheater help
I can not get the fuel preheater nipple to turn to remove the preheater. I tried everything so far including a hammer acutated impact. This thing will not budge. I feel sure it is not reverse threaded is it? Will I have to destroy this thing to get it out?
Sorry you are having trouble. I have never been into the fuel heater but according to the FSM the adapter is only supposed to be torqued to 24 ft. lbs. Someone may have used a loctite or other sealer. If that is the case it may take some heat to get it to move. Of course that brings in a whole new set of concerns like fire, and thread damage.
Get a piece of flat stock that fits good in the slot and an adjustable wrench to turn it. You'll get better leverage that way.
Without going out to look at mine.....can you get on the heater with a large water pump pliars and get the whole thing to rotate a little? When I pulled mine off to replace the gasket, I used a flat, spade, wood drill bit that fit nicely up in the slot on the stud. The bit had a hex on the shaft that I turned with a socket. If mine had been severely tight, I would have ground on the bit a touch to make it fit tighter and take off the sharp edge.
Good luck.
Good luck.
If it is Loctite it will take about 400 degrees F to turn back to liquid. I seem to remember that Loctite made a solvent. I never used it but I would like to try that before I got too drastic. Acetone might cut it, just don't get it on plastic like wire insulation or fuel lines. The problem using any liquid solvent is going to be keeping it wet to soak up into the threads.
Another product that has been around forever is Kroil. It is as good a penetrant as any I have used.
OOps! I didn't know about that. Your options are getting limited. Can a new fuel heater be obtained at a reasonable cost? This has turned into a major FUBAR.
