Fuel Line Help
Fuel Line Help
I got my injectors changed out today and put everything back together,
primed it up and went to start it up but it would not fire. I think I got the fuel lines crossed up hooking them up to the injector pump. Does anyone have a diagram or pic on how the fuel lines go #1-#6 on the VE Injector Pump for My 93?
sounds like your not finished bleeding your injectors, did you completely remove the lines? theres lots of pump and routing pics through out this site, a dodge parts site will identify individual line routing.
The lines lay in naturally in the right place.
One thing that confused me a bit. The VE pump cylinder numbering diagram in the FSM is viewed from the front of the pump, which doesn't seem natural to me. This image is from the FSM. If you look at the business (valve) end of the pump, the rotation is reversed. #1 is at the bottom, however.
ctd4stan
05-18-2009 02:56 PM
Tiara3100
01-14-2008 10:06 AM
RoadDiesel
06-16-2007 09:24 PM
Begle1
19
08-25-2006 11:31 PM
