fuel leaking from bottom of filter
Ever since it got colder I have a fuel leak from the bottom of the fuel filter. After the truck runs a bit it stops. I discussed it with David and I have not got around to doing anything about it. I am going to replace the filter but is there anything I need to look for to fix the leak? Thanks.
Make sure it's not coming from the fuel heater gasket and running down the side of the filter. That is a very common place for these to leak, especially when it gets cold.
If it's leaking from the drain/WIF sensor, you can replace it or you can get a filter that does not use the WIF sensor. Fleetguard 1221 or equivalent.
https://www.dieseltruckresource.com/...r-t258221.html
It's about replacing the whole fuel heater but it has good pics of the o-ring and heater.
pwrtripls1
Apr 30, 2008 01:45 PM
natlchamp2k4
Jan 15, 2007 10:24 PM
