Fuel leak from IP at aneroid vent?
Old Dec 20, 2008 | 05:37 PM
nosler45's Avatar
I have read through a lot of posts about this, and have only ever saw the fuel pin oring of being at fault.
The fuel leak on the IP was equivalent to a slow drip. So, I replaced the fuel pin oring with one in the Bosch kit. I started the truck and fuel eventually started spraying out of the vent. I replaced it again and it is doing the same thing.
Any ideas, because even if the oring was nicked it seems hard to believe that much fuel could get past a nick? I am confused!
Old Dec 20, 2008 | 05:52 PM
bgilbert's Avatar
You sure the fuel isn't leaking from the fuel drain banjo bolt? Do you have a aggressively ground fuel cone/pin? That will allow the pin to travel too far and cause a leak.
Old Dec 20, 2008 | 05:59 PM
nosler45's Avatar
I have a Denny T fuel pin?
When it was dripping I had a hose attached to the aneroid vent to make sure. Fuel was only coming from the vent. I dont have the rubber cap on there so it had enough pressure and volume to hit the master cylinder?
Old Dec 20, 2008 | 07:14 PM
That's a heck of a leak!
Past the o-ring is the only way fuel can get in there.
Old Dec 20, 2008 | 08:19 PM
nosler45's Avatar
Thanks! I guess I will have to check tomorrow to see if the pin is traveling too far? If I have to tear into this again, I'll be looking for a hole plug!
bigfoot
Jan 1, 2010 02:22 PM
97catintenn
Aug 7, 2009 08:23 PM
tomd
Dec 2, 2006 12:03 AM
schaef_12
Sep 28, 2006 09:14 PM
moparlvr
Jan 23, 2004 09:40 PM
