Aneroid Screw
Old Sep 28, 2006 | 07:30 PM
schaef_12's Avatar
Aneroid Screw
Anyone know if you can adjust Aneroid Screw on P7100 Pump?
Old Sep 28, 2006 | 07:48 PM
clutch1's Avatar
Yeah it is adjustable. I use it as a fine tune.
Old Sep 28, 2006 | 07:55 PM
schaef_12's Avatar
which way would a person go about adjusting it, Just turn it in a couple of turns and try it?
Old Sep 28, 2006 | 08:12 PM
schaef_12's Avatar
How do you adjust? Turn it in or out? Is it behind a "Cover" on the back of the pump?
Old Sep 28, 2006 | 09:04 PM
waldersha's Avatar
There is a cover on the back of the AFC. It has a break off screw that you have to get around, but not too hard to get off. Once off there is a stud that you will use a torx driver (15 if I remember right) You loosen the locknut and turn the screw in to increase smoke (fuel). Tighten nut back up and away you go.
Old Sep 28, 2006 | 09:14 PM
schaef_12's Avatar
thanks for the info
jmd4993
Jun 22, 2013 07:36 AM
nosler45
Dec 20, 2008 08:19 PM
tomd
Dec 2, 2006 12:03 AM
loudcummmin
Oct 3, 2005 02:44 PM
