fuel heater question
Old Dec 23, 2009 | 08:45 AM
billy-jay's Avatar
I put a 89 cummins in my 64 crewcab and never gave thought to the fuel heater.Is it wired hot all the time?I wired my fuel shutoff and ksb together and put the grid heaters on a push button.Ive not had any problems winter or summer but forgot about the fuel heater...thanks Jim
Old Dec 23, 2009 | 09:00 AM
Twisted Inc.'s Avatar
i'll be following this thread i need to know how to make mine work as well!
Old Dec 23, 2009 | 09:35 AM
JustRamIt91's Avatar
good question, i should look into getting a block heater too.
Old Dec 23, 2009 | 09:41 AM
HappyCamper's Avatar
The fuel heater recieves voltage from the ignition switch and the power is always on. It has a built in sensor that turns it on or off based on the temperature of the fuel. It is turned on at 43*F(6*C)
Old Dec 23, 2009 | 12:29 PM
billy-jay's Avatar
Thanks Rich...then I can wire it up off the key...hot all the time...maybe hook it up with the shutoff and ksb...Thanks Jim
Old Dec 24, 2009 | 12:38 PM
wow what a relief, i thought it was going to be much harder then that......ok i have a second question.....there are two prongs on the fuel heater plug in, one will get power from the ignition switch, (which one?) and what do i do with the second prong?
Old Dec 24, 2009 | 05:24 PM
One gets power, the other gets ground.
If you consider the hook for the weatherpak connector to be the bottom, power goes to the left prong.
Old Dec 24, 2009 | 05:31 PM
ok wanna thanks! now thats something i can wire up!
rjm022
Dec 11, 2019 09:17 PM
Ramrod90
Feb 3, 2009 07:39 AM
modiesel
Mar 7, 2008 10:44 AM
taildragger
Dec 4, 2006 10:00 AM
Reelay
Dec 1, 2005 06:14 PM
