Fuel additives and belt howl
What is this "blue stuff" i keep reading about at wally world? Im guessing wallys is walmart but ive been there and never found diesel fuel additives. There are a few different types of additives at the local napa too. whats the best stuff in ya'lls experience? Also i was flushing my radiator and when i finished the engine was squeeling somthin fierce. i thought it was the water pump but someone said put soap on the belt. this worked but did it fix the problem or just cover it up
There is are a couple of "blue stuffs" at Wally World (Walmart). My guess is Star*Tron Enzyme Fuel treatment. I am looking at a bottle right now and haven't tried it. It is for gas in the boat. Walmart has a few diesel fuel treats. I've tried PS but can't tell if it is that helpful or not. I have used mostly Lucas fuel injector cleaner. It has served me well, as I haven't replaced the IP yet. I ran out the last fill up so I am going to give Marvel Mystery oil a try. One gallon of MM treats 400 gallons of fuel according to the can and it is cheaper than Lucas.
i was thinking about getting tthat stuff as i have a 100 gal aux tank. so anything that treats 100+ is a-ok in my book. At least i think it was Marvel Mystery stuff. CYA incase thats just a nickname for it that goes way over my head
. How much is that stuff? Any word on soaping my belt?
Keep an ear for the squealing. If it persists, you could have a water pump weep hole problem. Easy fix, and not that costly, but it's something to stay on top of. When they go, they GO.
Daniel
Daniel
If it is leaking, you should be able to see a trickle of antifreeze running down the front of the block by looking straight down the engine. a leaking waterpump can cause the squealing your experiencing...antifreeze on the belt makes a loud squeal.....
bigsam
Mar 8, 2007 08:59 PM
odie2219
Mar 22, 2004 05:24 PM
. Also, any tips on replacing the pump.
