Max transmission temp?
Old May 22, 2007 | 10:27 AM
ixx's Avatar
ixx
What is considered high and what is normal? Dont have a guage yet but want one when the money comes (if ever)
Old May 22, 2007 | 12:21 PM
Tuckerdee's Avatar
Well...this could open a big can o worms.
"Normal" would be coolant temp since the coolant cools the transmission. So right around 185*. Mine seems to settle in at 160* going down the road (that's in the pan).
"High" would be, to me, anything over something like 250*. Sure, your temp is going to go up and down depending on load, etc. The temp sensor on the tranny cuts the O/D out at 280*. So technically that is "high" (from Chrysler's view).
I just saw a graph the other day. It more less said for every 10* cooler you can keep the fluid, you double the life of the fluid. And for every 20* cooler you can keep the fluid, you double the life of the transmission.
So...keep the fluid as cool as you can!
ngkefalides
0
Aug 12, 2008 08:33 PM
Dually Driver
13
Nov 13, 2007 09:10 PM
belfert
Sep 9, 2004 03:23 PM
fishin fever
Feb 22, 2004 08:32 PM
Zino
Aug 15, 2003 10:14 PM
