Front wheel bearing
Old Dec 26, 2018 | 03:05 PM
TJE's Avatar
TJE
Front wheel bearing
What’s a good quality bearing?? I had the fronts replaced in May of this year, and I’m gonna have to replace the left side for the second time since September!
Thanks,Tony!
Old Dec 26, 2018 | 04:08 PM
Eh, summin, noot riiggt.
Are you changing the matched set, bearings and races?
Following fsm for torque sequence?
More info pls.
Old Dec 26, 2018 | 04:13 PM
TJE's Avatar
TJE
I had them changed at a local shop....never again. Everything was supposed to be changed inner, outer races, etc, etc. I’m not sure what is failing?? ( parts or workmanship) I know I’m not going back!
Old Dec 26, 2018 | 04:42 PM
Fwiw,
A lot of shops just throw a new set of bearing cones in, without changing races, because it's fast and easy. Problem is that aftermarket companies are not required to have exacting inner measurements of OEM parts. This means as long as the id of the cone side, and the od of the race are correct, bearing design can vary, by size, number of rollers, cage design, etc.
I bought my Dodge, having an immediate rear wheel bearing issue. The wb was just replaced. They did not match race to cone, and the rollers actually rolled outside the race's inner diameter, riding 20% on air.
Great, eh?
Overtightening, etc... You'll have to disassemble it to find,out why?
Old Dec 30, 2018 | 03:13 PM
TJE's Avatar
TJE
I changed the bearings on Saturday! I found the driver side almost dry! The race was rusted onto the spindle. There was very little grease on/in the bearing and none in the inner part of the housing. I also replaced the passenger side, it did have some grease but not much.
Nothing like doing a job yourself!
Old Dec 30, 2018 | 03:28 PM
Well that sucks big time! How much is a bit of grease...sure they charged you for a tube of it on your invoice, but only put a dab here and there.
Old Dec 30, 2018 | 07:47 PM
TJE's Avatar
TJE
The bearing was already leaving wear marks on the outside of the race! It had enough grease to say it wasn’t dry and that was it. I’m not understanding how it went from packed with grease in September to having to replace the bearing in December? Oh well...on to the next project 😁
Old Jan 1, 2019 | 10:40 AM
PapeCAT's Avatar
Timkin roller bearings, races and wheel seals are usually my go-to. Napa might have some other acceptable options but with the affordable price of the real deal (timkin invented the tapered roller bearing, after all) there really isn't much of a choice.
GLHS
Apr 15, 2012 08:10 PM
silverbullet02
Oct 5, 2009 12:16 PM
Wilbur01
Aug 3, 2009 11:16 PM
Hawkeye
Apr 29, 2008 10:24 AM
