Front Struts
Old Apr 23, 2010 | 11:27 AM
whosdunit's Avatar
Front Struts
Everybody agrees seems like, that the frontends wham!, a lot ,are our front struts big enough,or strong enough? Anybody out there ever do any exper-i-menting with them?
Old Apr 23, 2010 | 07:46 PM
Struts? You mean the strut rods that locate the lower control arms?
The front of my truck rides nice and cushy, it's the rear that gives me a kick in the pants over every bump.
Old Apr 23, 2010 | 08:45 PM
whosdunit's Avatar
Hey , wana ,yes sir . What do the struts really do ?, support the lower (A frame),and keep the wheels in line/ ( mine is a d350) w/ 36 in. ext cab .the back end ain't so bad its the front end that whammmms.
Old Apr 24, 2010 | 11:31 AM
getstucksome's Avatar
How do your front bumpstops looks? Mine whammed! and I was missing a lower control arm bumpstop
Old Apr 24, 2010 | 12:58 PM
whosdunit's Avatar
I've been keeping an eye on the stops, they look great not marked or beat up ,top's or bottom's. I think "jim", or one of you guy's had trouble with his strut bushings (new poly's i think).My f250 has heavy ,heavy front strut's. soooo,i'm think'n------maybe they need to be stouter? Just trying to make a better ride. thank's for the reply.
Old Apr 25, 2010 | 01:55 PM
The struts locate the front wheels on the fore/aft axis.
I'd start with new shocks.
Old Apr 25, 2010 | 03:02 PM
whosdunit's Avatar
hey , wana ,thanks . i have new shocks frt., & bak., i understand the theory of how they work . what or how much did you do to the frnt., of your trk.,to get a soft, cushy ride?The pic.,of your trk., looks up & level
Old Apr 25, 2010 | 03:26 PM
93DodgeRam's Avatar
It's a good idea to check the bolts holding the strut rods to the lower control arms. On my truck, the washers broke, allowing movement between the rods and control arms. This leads to elongation of the holes in the control arms and problems with alignment. Underneath, check for signs of movement between bolts and control arms. I replaced my bolts with brand new grade 8 hardware.
How are your strut rod bushings?
A tip... If you have to remove the rod and the front nuts are not cooperating, chop out the rear halves of the bushings and cut the rear retainers, then slide the rod forward. After it's out, you can cut off the old nuts and replace with Moog nuts. My truck saw a lot of salt and I learned this the hard way...
Old Apr 28, 2010 | 07:23 PM
I didn't do anything to it, it's always rode good.
It sounds like you might have beefier springs. How much clearance is there between the upper control arms and the bumpstops on the frame?
Old Apr 28, 2010 | 10:18 PM
whosdunit's Avatar
Wana, measured @1.5 in. top ,both sides &3-3.5 on bottom both sides. After seeing your trk., and a couple of the others on the forum,,,these could well be the origional springs. Aiso the cab bushings look somewhat crushed. Has anyone used McQuary-Norris springs?,#FCS7172s,not sure about no.
eightball
Apr 7, 2009 10:59 AM
truckjunkie
Nov 20, 2008 07:36 AM
capt.Ron
Apr 27, 2008 12:28 PM
MTGunNut
Nov 4, 2007 01:02 AM
