Front gear case
Old Dec 21, 2004 | 12:04 PM
Ggg's Avatar
Ggg
Front gear case
I have heard the 94+ have a different front of engine gear case, compared to the 93- 12V. If this is true does the tin cover that bolts to the front of the gear case need to be changed too, or will the old one still fit the 94+ gear case. I am wanting to change the IP to a P7100 and I was told the gear case must be changed too.
Old Dec 21, 2004 | 04:11 PM
Good question. I don't know, but I do have two different KDP jigs for 1st and 2nd gen trucks. Bolt spacing is the same, but they hit the case at different spots. Maybe the best thing to do is ask the Cummins dealer to look up replacement covers by CPL# using your CPL and a CPL for a 2nd gen (2175 would be a good one). If the replacement cover is the same part #, you don't need it.
Old Dec 21, 2004 | 05:15 PM
Ggg's Avatar
Ggg
Thanks, I will do that.
While I am on the subject, why do I need to change the gear case for the P-pump? Is it only that the P-pump has a different bolt pattern, if so couldn't I just drill and tap for the P pump bolt pattern. Or is there more to it.
Old Dec 21, 2004 | 05:26 PM
The VE pump seals to the case with a gasket, the P-pump slides into a recess in the case. There's more to it than bolt pattern.
Old Dec 21, 2004 | 05:34 PM
Ggg's Avatar
Ggg
Thank you very much Dave.
wyododge
Aug 18, 2011 07:48 AM
Mr. Plaine
Jun 14, 2005 09:40 PM
redmist
Sep 23, 2003 07:24 PM
Haulin_in_Dixie
Sep 5, 2003 10:10 AM
