Timing gear case bolts
Old Sep 21, 2003 | 07:46 PM
redmist's Avatar
Hi guys,
Can anyone tell me how many bolts hold the the timing gear case in place? as I'm tabbing the kdp and would like to check the torque values on these bolts and I don't want to miss any.
I have read some where that some of these bolts where found loose and on some occasion had drop out causing just as much damage as the kdp.
I just want to make sure that I get them all checked, so far I have found 3 including the one that is used for the tab.
All help apprecaited____________redmist
Old Sep 22, 2003 | 10:23 PM
torquefan's Avatar
Re:Timing gear case bolts
I believe there are five under the gear cover: one beside the KDP, one down by the oil pump, and three behind the cam gear. I have modified a 10mm open end wrench to tighten these three through the holes in the cam gear. If you bar over the engine, and use a small mirror, you should be able to see them.
Old Sep 23, 2003 | 07:24 PM
redmist's Avatar
Torquefan
Thanks for the info, much apprecaited____________redmist
IRoss
May 3, 2008 01:43 PM
steven
Aug 14, 2006 02:49 PM
blueberry
Dec 13, 2005 06:17 PM
Rattlerattle
May 2, 2004 10:13 PM
