Front Drive Shaft.
Old Oct 29, 2012 | 06:04 AM
bannerd's Avatar
Front Drive Shaft.
Hello all, took the truck out back to haul some wood and while going over some rocks I heard a snap.. Thinking it was the new suspension I put on everything looked good. Went to check the universals and I noticed my front drive shaft snapped. I took the shaft off the truck and I notice that where the front drive shaft there is three metal square things that fell out into my hand.. some other pieces of metal. I can still see the ball in there. Also notice this piece was totally destroyed.
http://quad4x4.com/qu40836.html
What do you guys think I should do? Buy a new shaft or try to rebuild the joint? Basically all of this stuff http://quad4x4.com/qu40741.html is destroyed.
Old Oct 29, 2012 | 07:53 AM
peckens's Avatar
i would just rebuild, probably just got corroded with age, however i would look for an entire double-cardon kit that has the ball. they arent that hard to replace. i am not sure if these shafts have to be have to be pressed in, but usually they do.
Old Oct 29, 2012 | 11:29 AM
BILTIT's Avatar
From a ford but should be similar:
http://www.ford-trucks.com/forums/10...-vid-pics.html
Old Oct 29, 2012 | 01:41 PM
peckens's Avatar
if you can install new ujoints you can do this as well. the trick is to keep that spring in the center while reinstalling the joint to the shaft. When i did it I shoved a bunch of grease over the spring to hold it in place.
Old Jan 7, 2013 | 01:01 PM
bannerd's Avatar
Does anyone know the way these go together? I assume you drop the washer in first, spring, then the three metal spaces, then the thicker washer then the seal ?
Old Jan 8, 2013 | 06:12 AM
bannerd's Avatar
This is the way they go together;
Old Jan 8, 2013 | 09:00 AM
rebal's Avatar
I ended up just buying a reman front shaft from Napa because my slip yoke was loose too . fwiw
Old Jan 8, 2013 | 09:09 AM
bannerd's Avatar
Yeah, I might need to use a pickel fork to get that ball off. It's on there pretty tight, :P
Old Jan 8, 2013 | 09:10 AM
bannerd's Avatar
Mind if I ask you how much it was?
Old Jan 8, 2013 | 04:32 PM
barrytransport's Avatar
aft - Front
Back to Results
3 Images
<< Prev Next >>
Front
Part: NMD 931364 Product Line: NAPA MaxDrive
List Price
Core List Price
Your Cost
Unit
415.44
60.00
207.72
Each
Qty Available: 0
Qty
Features & Benefits
Each Prop Shaft Includes 100% New Universal Joints To Ensure Proper Fit & Function For Optimal Performance & Durability; Each Driveshaft Is 100% Dynamically Balanced To Reduce Vibration & Increases Joint Life.; Every Shaft Is Measured To OE Specification to Guarantee Proper Fit and Function
ProTech Bulletin: Prop Shaft Do's And Don'ts
Installation Instructions
Attributes
4x4 Driveshaft Length : 24 3/4"
Warranty
Limited Lifetime, Replacement Will Be Issued for Unit that Proves Defective During Normal Use on the Vehicle on Which It Was Originally Installed. Extended Only to the Owner of the Vehicle on Which the Unit is Installed-Not Transferable.
Warranty PDF
Material Safety Data Sheet (MSDS)
There is no MSDS for this item
Application Information: 1991 Dodge Truck W250 3/4 Ton 4WD - Pickup
Comments: w/ Manual Transmission;w/ 4,500 lb. Front Axle;w / Dana Model 60 Axle;w/ Heavy Duty Transfer Case
Per Car Qty.: 1
MCMLV
Oct 19, 2004 08:36 AM
TON4FUN
Aug 2, 2004 07:58 PM
cwbronc
Dec 21, 2003 02:48 PM
shaft
Jun 30, 2003 02:37 PM
bkay
Dec 12, 2002 05:22 PM
