Which front disk?
Old Jun 10, 2011 | 08:49 PM
mhuppertz's Avatar
Which front disk?
Napa seems to indicate that there are two different rotors for our trucks with 4 wheel drive and the 4,500lb axle. Is that right?
Old Jun 10, 2011 | 09:36 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
they always try to sell me the thin ones. if they have them in stock (which my store did) compare them and get the thicker ones.
sorry for not having good facts but thats what i did when napa did the same thing with me.
Old Jun 10, 2011 | 10:17 PM
simplysmn's Avatar
Yes 4500 lb axle
Old Jun 10, 2011 | 11:34 PM
mhuppertz's Avatar
Is this the right one?
Rotor - Front - Premium
Part Number: NB 4885843
Product Line: NAPA Brakes Rotors
Attributes:
# of Bolt Holes : 8
Bolt Circle Diameter : 6.5"
Brake Rotor Diameter : 12.87"
Brake Rotor Discard Thickness : 1.46"
Brake Rotor Thickness New : 1.54"
Brake Rotor Type : Disc Brake Rotor Only
Center Hole Diameter : 5.01"
Height : 3.08"
Maximum Lateral Runout : .004"
Mounting Type : Type L - Rotor Only. The Rotor Is Mounted Inboard Of The Hub. The Hub & Rotor Sections Are Bolted Together. Replace The Complete Assembly If Hub Flange Is Bent Or Damaged. See Diagram For More Information.
Vented / Solid : Vented
Features and Benefits:NAPA Premium Rotors Are Designed To Improve Stopping Distances, Minimize Brake Fade & Extend Pad & Rotor Life.
The Non-Directional Finish On NAPA Premium Rotors Reduces Noise & Braking Roughness.
Vane Configuration Reduces Temperatures & Improves Performance.
Warranty:12 Months or 12,000 Miles Whichever Occurs First
Warranty PDF
Important Information:w/ 4,500 lb. Axle
Rotor Casting # 100353
Have questions about this item?Call your local NAPA AUTO PARTS Store at 800-LET-NAPA (800-538-6272)
Available For Reserve
1700 Eubank St Ne Albuquerq...
Store Number: (505) 294 - 1544
$67.97/ea
Quantity:Add to Cart
In Store FAQs
What is Reserve Online?
Why reserve your items online?
How it works
Out-of-Stock or Unavailable Items
Old Jun 10, 2011 | 11:41 PM
DPFservice's Avatar
That's the set I bought(the thicker of the two offered). Seem to be decent quality after 5-10k miles.
Old Jun 11, 2011 | 12:03 AM
roxxx's Avatar
Before you leave the store look in both boxes!!! may sound trivial BUT
I have a bad habit of opening everything at store,
Napa has Old and new stock with different spec we went through 7 orders to get matched set with same sku number on each Some were vented some were thick Just look at store
Same as Wagner I had another store order me a set. one had vents one didn't he said the were okay to put on miss matched I said Kiss it
Old Jun 12, 2011 | 09:55 AM
cougar's Avatar
My 91 kept warping "OEM" rotors, so I got some good drilled and slotted ones. No more problem with warped rotors.
Old Jun 12, 2011 | 10:44 AM
mhuppertz's Avatar
Spendy? Which ones did you get?
Old Jun 12, 2011 | 11:02 AM
ChrisLib's Avatar
I use these, very happy with them so far. No warpage/vibrations/squeel etc and they are so far holding up rustwise VERY well.
http://brakeperformance.com/brake-ro...ake-Rotors.php
Old Jun 12, 2011 | 12:43 PM
cougar's Avatar
These, the spendy ones.
http://brakeperformance.com/brake-ro...s.php?did=9362
Can't complain about the price considering how often I had to turn or replace the OEM ones.
My 92 doesn't seem to have the same problem. Strange considering it is an automatic.
Old Jun 12, 2011 | 01:06 PM
maybe368's Avatar
That is a whole kit for 215 bucks and free shipping...What is not spendy? Mark
mhuppertz
Apr 3, 2010 05:14 PM
winkdemon
Aug 3, 2009 04:13 PM
cconrad331
Jan 27, 2008 09:47 AM
DSjockey
34
Jul 20, 2007 07:03 PM
W.F.O.
15
Apr 5, 2006 02:11 PM
