Front brakes sticking
Old Jul 26, 2008 | 10:03 PM
Capp's Avatar
Question Front brakes sticking
My Dad's friend was using his truck today, a 91 D350, and the front brakes started sticking. Does anyone have a link for rebuilding the caliber. I searched but didn't find anything. Mine did this a long time ago and I took it to the shop, but his freind said he would do it if he knew how. The truck did sit for a while before he used it.
Old Jul 27, 2008 | 12:19 AM
simplysmn's Avatar
most likly easier to just go down to Napa and buy a set of caliper's put em on and forget about em
Old Jul 27, 2008 | 04:02 PM
More likely the slides are rusted. Pull the calipers off, wire brush the sliding surfaces of the caliper and caliper bracket, apply anti-seize, and re-assemble. Repeat every 6 months for best results.
Old Jul 27, 2008 | 05:23 PM
snowjoker's Avatar
Dont use anti-sieze on the sliders i was told it will eat up the rubber.. Use good silicone brake grease, or something synthetic. Anti sieze will actually wash out of there. Once in a year to pull them apart and do a preventitive maintenance on the slide pins will make your brakes last much longer, and keep things trouble free.
Old Jul 28, 2008 | 04:56 PM
What rubber? Our brakes sliders are metal on metal, exposed to the elements - which is why they require regular maintenance.
Old Jul 28, 2008 | 05:25 PM
snowjoker's Avatar
Sorry I am a GM man, and now own my first dodge, the gm calipers have rubber in the slider assemblys. BUT antizieze will wash out with the elements, Your better using a silicone based lubricant that will repel water than to use that grey goop, althoguh it does its job well on keeping bolts lose, its not intended as a lubricant...
Old Jul 28, 2008 | 06:01 PM
smoking's Avatar
Hoses can collapse internally and cause this also!
Old Jul 28, 2008 | 08:54 PM
mhuppertz's Avatar
I polished one of my caliper/slider surfaces and used hi-temp moly wheel bearing grease, and the problem went away. Now my fronts are wearing evenly.
toddlaco
Sep 24, 2007 09:55 AM
Tommy93w350
Dec 17, 2006 01:46 PM
storx
Aug 2, 2006 11:21 PM
MNorby
Jul 9, 2005 10:24 PM
dingo
Oct 29, 2003 06:56 PM
