fram oil filter
fram oil filter
alright, well right off the bat i put a fram oil filter on my truck before i even knew about this site, and now i see some people say they are no good, so how come they are so bad, what would you suggest?
I wouldn't panic as many many vehicles die of old age, never having anything but a FRAM filter on them.
There are still people that think that FRAM is as good as it gets; I know in my little lost-from-time area, even the best mechanics think anything less than FRAM is second-class.
Now I know better and use FleetGuard 3894(I think) for the oil and Fleetguard FS1221 for the fuel.
There have been instances of the filter media collapsing or breaking up and clogging small passages in the engine such as the piston cooling nozzles. They are a cheap filter, and you get what you pay for.
fram had to pay for a lot of cummins motors as stated by MSM i am shure fram has it fixed by now but the life of your motor depends on a good filter if you will use fleetguard lf16035 it will fit on every year modle
im thinkin bout using wix filters a tiny little auto parts store down the rolad from my house carries them, they have a good rep. around here what do u all think
Wix, Pure One, and Mobil1 are among the best rated multi-pass SAE rated filters. I am not loyal to any one but I do stick with one of the three. I know most industrial applications use FleetGaurd and those engines go on for thousands of hours of heavy use, so they must be good too.
Fleetguard, Wix, Hastings/Baldwin, Donaldson are all top shelf stuff.
Check your local truck parts store when filter shopping. I can get a Donaldson for $5.50 when Pep Boys wants $13 for a Purolator. Now, Purolators are OK filters but they aren't worth more than double a Donaldson.
fram is just fine we have 30+ deisels that have all fram stuff and we have no issues i run fram on my truck, my parts guy sell 10s of thousands frams each year and said hes never had on back, im not loyal to them but they never let me down
May never have a problem, but when you see a Fram cut open, it is just glued together cheaply and others have metal clamping the media in place.
I have heard in hot race engines the glue may melt and all heck happens. It can also fail internally more easily.
Like a KDP, you may never see a killer under your hood, but turn on the net and yikes!
Cut one open and look at it.
I have seen several that were blown apart and NOTHING was getting filtered.
CUMMINS says no warantee if a fram is on it. They know a bunch more than we do.
