Found my Trans leak
Old Sep 23, 2011 | 11:08 PM
Found my Trans leak
Umm yea, found my trans leak. 2 completely backed out top cover bolts and the rest were finger tight.....
(Before cleaning) See loose bolts. Oil was spraying or leaking onto the exhaust and smoking....
Primered
Painted
The removal off driveline went smooth today, hopefully the install tomorrow is just as smooth. Just cleaner!
Brandon
Old Sep 24, 2011 | 02:38 AM
schamran's Avatar
Someone must have had it out of the truck and not tightened them. When I took my trans out today the speedo wiring harness had two clips that bolted to the cover on the 2nd and last bolt from the front passenger side of the trans. Were yours just hanging out?
Old Sep 24, 2011 | 08:59 AM
Primered
Painted
Brandon
Brandon,
That thing is way too pretty to put into your truck. How about the center of the dining room table. Add a few lights, and you're good to go for thanksgiving dinner.
What do you say ?????
Old Sep 24, 2011 | 06:19 PM
1990's Avatar
What's up with the shifter stub? Backwards?
Old Sep 24, 2011 | 06:35 PM
Jim Lane's Avatar
Thumbs down
That gives you a very short shifter throw.
I would locktite them or cross drill the bolts and install a saftey wire to anything inaccessable.
Jim
Old Sep 24, 2011 | 11:36 PM
removing the side screws in the tower and Turning the shifter stub backwards allows it to come out of the hole in the floor.....
It's all back together and feeling great, the clutch is AWESOME feeling. you can tell it has alot more clamp force but it engages so smooth! smooth if not smoother than the junky sachs that was in it
Old Sep 25, 2011 | 07:56 AM
GIT-R-DONE's Avatar
I hope you permatexed the top on reinstall.
blackram2500
Apr 29, 2010 04:36 PM
SmokinFive9 4x4
Feb 27, 2005 04:48 AM
HorseHauler
Oct 12, 2004 10:53 PM
signature600
Aug 7, 2004 05:59 PM
DieselDaze
Feb 4, 2003 07:07 PM
