Flame thrower exhaust.
Old Nov 30, 2009 | 04:27 PM
JustRamIt91's Avatar
After talking to the diesel mechanic today, i am un-able to think of a different name for this.
Tell me what you think about this idea.(won't actually try this)
Propane injection just before the turbo.
The theory seems to be good. (Like the NOS effect on cars, but for diesels) Increasing heat before the turbo to make it spool faster and create more boost and launch you forward like a rocket.
Negative effects might be a burnt turbo, too much boost and could have explosive results.
Cool side effect could be a flame shooting from your exhaust.
I assume this would be for drag race purposes only. Unable to find anything on this.
He also showed me a smoked turbo out of an international 454 after one of the drivers turned up the injection pump(wish i had pictures), this thing was melted. It also needed new pistons, sleeves and bearings. I drove the truck back to the yard and it felt better than new.
Old Nov 30, 2009 | 05:48 PM
BC847's Avatar
1st Generation Admin
Video your results and let us know how that works out.
Old Nov 30, 2009 | 07:24 PM
1985cucv's Avatar
yeah sounds like a 100 horsepower sticker. go for it i want to see some destruction. just dont try it on a cummins it would be a waste try it on some other diesel
Old Nov 30, 2009 | 07:53 PM
Riflemanusmc's Avatar
Registered user
Yea....Don't do it....QUOTE from my early USMC training days. When the pin is pulled, Mr. Grenade is no longer your friend....
Old Nov 30, 2009 | 08:27 PM
Originally Posted by JustRamIt91
....(won't actually try this)...
Just let me reiterate this....im not actually going to do this.
Old Nov 30, 2009 | 08:29 PM
madhat's Avatar
Administrator/Jarhead
What are you trying to accomplish here? Faster spool or flames out of the pipe? Or sending the compressor wheel to the moon?
Old Nov 30, 2009 | 08:31 PM
i honestly don't know, im just curious as to what may or may not happen. This will not be done on anything i own.
Old Nov 30, 2009 | 08:38 PM
madhat's Avatar
Well, I know this guy that has sprayed nitrous down his intake a couple of times on the dyno... nothing bad happened. The same effect would happen if I, er, HE... would have had it plumbed in the normal way.
Old Nov 30, 2009 | 08:43 PM
Registered user
I'm out...
Old Nov 30, 2009 | 08:45 PM
Registered user
Yea Brother. You've got alot of room for dishing it out...
Old Nov 30, 2009 | 08:52 PM
madhat's Avatar
I'm not dishing it out... I'm trying to figure out what he wants so he can tear it up the right way...
Old Nov 30, 2009 | 09:07 PM
Ok now im going to have to find a **** truck from work to do this on.... i'll mill around the yard tomorrow and see what i can or what i can't find really. How about a 7.3 or 6.5? are their turbos/exhaust manifolds easy to get to? I think you would just want a momentairy blast and set a hobbs switch, normally closed to open at 40lbs or what ever you feel your limit to be, this would then eliminate turbo lag and let you rock and roll. Does that sound good? They have a few "junk trucks" i could probably hook a system up to using a bottle, regulator, solenoid, hobbs switch and some sort of delivery system to turbo.
Old Nov 30, 2009 | 09:14 PM
madhat's Avatar
Nah, you don't want to deliver it to the turbo, you want it pre intercooler, or post turbo on a non IC truck. The exhaust gasses coming out of the motor are what make the turbo spool faster, not what is going into it. (kinda)
I do not know what kind of reaction that propane will have, tho. I don't fool with that at all, so I am not sure what to tell you. I personally would not spray propane into a truck. Not even a ford...
Old Nov 30, 2009 | 09:19 PM
this is sorta what i had in mind... for the flame thrower idea... kinda would need a spray jet or injector so it would mist and exhaust gases would ignite it.
Old Nov 30, 2009 | 09:23 PM
ttcfan4476's Avatar
you never know it might be the next big thing some has to try stuff to see if it works or we wont have any thing to do. just like doin twins some one had a lot of time invested to get them to work.
