First problem, clunk!
Old Jun 17, 2006 | 11:37 PM
edwinsmith's Avatar
I type with two fingers and a thumb if that makes you feel any slower.
Heck, I can use 5 fingers. 3 on one hand and 2 on the other.
I think the thumping is pretty normal for the GetRag. Mine does it too. Somebody told me it is the cluster gear rattling in 4th gear.
Edwin
Old Jun 23, 2006 | 04:10 PM
naw_t's Avatar
clunk found
I finnaly got a chance to take the cover off the rear axle. Missing three teeth on the ring gear. What gears do I have? Numbers are
9 03 97 DANA D 39287 P4L49 46 13 3 89
Speeking greek?
Nawt
Old Jun 23, 2006 | 04:31 PM
Oooh, that's ugly. Looks like whatever was floating around in there wore down the tone ring too.
Old Jun 23, 2006 | 04:33 PM
naw_t's Avatar
yep
Guess you found my pics huh..
So what gears are they? I thought the 5 speed came with 3.54 ratio. But I can not decifer the numbers on the ring gear.
Old Jun 23, 2006 | 04:41 PM
apwatson50's Avatar
I don't think the numbers on the ring gear say, unless there is some code book or something. So you will probably have to do it the old fashion way, count number teeth on ring gear, count number on pinion and divide.
Unless the tag is still on one of the inpection cover bolts then it'll say on that.
Old Jun 23, 2006 | 04:42 PM
I really couldn't tell you. Was there a sheetmetal tag on the diff or did somebody already lose it for you? If all else fails you can count teeth and do the math. Your only options are 3.54's or 4:10's. Both were available with the 5 speed. Most trucks have 3.54's, but most of the trucks with 4:10's are 4x4 duallys.
Old Jun 23, 2006 | 05:26 PM
G1625S's Avatar
Total bummer about the rear-end. I knew that description sounded familiar Every Dana axle has a Bill of Materials (BOM) number stamped into the passenger side axle tube. It should be close to the center section, but it could be anywhere. I think it's 9 digits. You may have to get crafty with the wire brush to make the numbers/letters show up, but it'll be worth it because from that BOM, any reputable gear shop will know more about your truck than you do...and you'll get all the proper shim assortments, bearings, races, seals etc. It's a beautiful number to have when shopping for parts for that axle. Sorry again about your misfortune
Old Jun 23, 2006 | 05:50 PM
naw_t's Avatar
thanks
I know about the BOM I just have ta find it. Old nast truck under neath. I did post up pics in my gallerie of my fleet.
Thanks for all the help I still think the truck was worth the $1K.
Nawt
Old Jun 23, 2006 | 06:07 PM
G1625S's Avatar
Nawt
I'd say! You could part it out on E-Bay for 4 times that of you get tired of it.
edit: I got genuine Dana/Spicer r@p, american bearings/seals etc. for mine and it was only about 400 bucks..plus lots of labor and swearing...man that Detroit was heavy Oh, and no case spreader, so I had to smack the thing in and out with a 5 lb plastic mallet.....6 times! Ok, I'm done whining
Old Jun 23, 2006 | 06:10 PM
Redleg's Avatar
Expect/inspect more than just the gear. It sounds like the guide pin to the spider's tried riding up and hit the gear. It probably hit the pinion, whch then damaged the ring. The bore in the carrier it rides in is probably egg-shaped. When mine did it, it bent the guide pin after it was sticking up, so it couldn't get pushed back in to free up the axle.
Old Jun 23, 2006 | 06:45 PM
dodgenstein's Avatar
The 46 and 13 in the ring gear codes are your tooth counts. You have a 3.54 rear.
Old Jun 23, 2006 | 09:01 PM
naw_t's Avatar
thanks
Now the search is on, thanks for all the help.
Nawt
Old Jun 24, 2006 | 05:20 PM
ruquik's Avatar
My mystery clunk turned out to be the original spicer u joint at the rear diff being lubricated by a magical red dust.
Old Jun 24, 2006 | 09:26 PM
Well, that's a relief! Much cheaper and easier than an R&P R&R.
mstep3
Jul 7, 2010 05:36 PM
Cummins610
17
May 29, 2010 12:50 AM
MasseyMan1089
May 23, 2007 07:56 PM
dpeder
Feb 21, 2006 11:34 AM
slimchase
0
May 14, 2003 10:06 AM
