Finished auto to getrag
Old Oct 30, 2023 | 04:04 PM
Bmillzthe2nd's Avatar
Hey guys am I missing something? (3.54 rear end gear ratio) With the auto I could top out around 90 with more room to spare. Now with the getrag the truck is screaming around 45 in 4th and 65 in 5 so I pretty much always have to use 5th which I was hoping wouldn't be the occasion. I told the trans shop(trans gear performance) my gear ratio. Although it's a bit tough to hear the engine because I haven't closed the floor yet still waiting for my shifter boot to arrive.
Old Oct 30, 2023 | 04:12 PM
Keep in mind this is according to google maps because my speedo says im going 90 while google maps says im going 60.
Old Oct 30, 2023 | 06:46 PM
edwinsmith's Avatar
Use Google maps speed and the radar cop will let you know if it's right.
Old Oct 30, 2023 | 07:15 PM
u2slow's Avatar
Probably a different speedo output on the trans. The getrag usually has a right-angle gear reducer before it goes into the speedo widget.
Edit: did your auto have OD? If so, its OD ratio is taller than the 5spd.
Old Oct 30, 2023 | 08:23 PM
Thanks man this really clears things up yea my a518 had o/d. The overdrive failed which is why I did the swap do you know where I can find the correct gear reducer?
Old Oct 31, 2023 | 12:59 AM
u2slow's Avatar
The factory ones are on parts trucks.
You can google for generic ones, like here:
https://transmissioncenter.net/shop/...-888-201-2066/
But you need to know how far apart your actual speed and speedometer are to choose the right ratio.
Old Oct 31, 2023 | 10:20 AM
Alright so if my speedo says I'm going 92 while google maps says I'm going 62 which one would I need?
Old Oct 31, 2023 | 02:59 PM
Best way to figure out exact speed is to have someone pace you in their vehicle with a known good speedo. You do 50 mph and they match your speed and then let you know what speed they were doing, then it's some simple math after that to figure out if your need an increase or reduction ratio adapter.
Old Oct 31, 2023 | 03:03 PM
Speedo says I'm doing 98 while I'm actually doing 63.
Old Nov 1, 2023 | 02:25 PM
u2slow's Avatar
divide one number into the other.
1: 0.674
(Input: output)
Old Nov 6, 2023 | 08:19 PM
1: 0.674
(Input: output)
I contacted patc they got it straightened out just waiting for the adapter to arrive.
Falcon1
Nov 19, 2010 11:21 AM
dieselmaniac25
Mar 13, 2009 11:10 AM
crossy
Aug 26, 2007 01:38 PM
Terraizer
Apr 19, 2007 09:41 PM
59FORD
Mar 13, 2005 08:16 AM
