Finally
Finally
I finally got the used IP I bought back in late November. the late delivery is a closed story now that I have it in my possesion, but I do havea question.
On my '93 the throttle linkage has a spring that rides on a pin (they are both worn part way thru), but on the used pump ('91 I think) the linkage is different, the pin and spring are up under the linkage instead of exposed like mine.
Is the pump essentially the same, and interchangeable, witht eh exception of the KSP?
I also got the stock early sticks to go with it, but kKnow thy won't work on my '93. Are they resellable?
I*s there anything I should do or look for before putting it on?
It is supposed to have come off of a totally stock truck w/200K + on it. It's a little grungy on the back side, and looks to have had a slight oil leak at the timing cover seal, but otherwise not too bad.
You might consider doing a seal job on it. It isn't that difficult and you only need one special tool which you can buy online. The seal kit costs about $20 and you may need to purchase the front seal separately. With that many miles it's probably ready to start leaking. It's a bit of work to yank it back off again.
What year are the injectors from?
Edwin
Edwin
03quadduallyho
Mar 24, 2003 05:34 PM
admin
38
Nov 12, 2002 03:26 PM
RJMontana
Oct 9, 2002 08:17 PM
tobyw
Oct 7, 2002 05:49 AM
