milage? after turning pump up
Old Mar 12, 2008 | 06:40 PM
redneck2thamax's Avatar
im thinking about turning my injector pump up but when diesel is 3.70 a gallon i can't afford to really waste to much. what is some of yalls milage like after you turned your injector pump up?
thanks
______________________
89 d250 2wd diesel, 4.10 gears straight pipe, performance injector pump, 5 inch exhaust tip, front and rear end homemade ranch hand bumpers, head ache rack soon to come.
Old Mar 12, 2008 | 07:16 PM
jdwest's Avatar
Mine is turned up with the fuel screw one turn from run away and my star wheel down just enough to keep from binding. I get combined city/highway of 18, give or take 1mpg either way. This directly relates to the weight of my right foot! If I stay on the highway running 60-65mph, I have seen as high as 22mpg.
Old Mar 12, 2008 | 09:00 PM
JQmile's Avatar
Same going on here...if I stay out of it I am fine. Hey, I have that "falling off paint" option too!
Old Mar 12, 2008 | 11:26 PM
Palerider's Avatar
Mine used to get about 18-21 with stock injectors and before the pump was massaged and turned up. Now about 13mpg loaded, 17mpg freeway not pulling, give or take a mile if I stay down around 60-65mph. If I run 70-75 on the freeway, about 15mpg. Lots of power now and it runs real good, but I really think it was the injectors that killed my mileage. The dreaded tradeoff.
Anyone recognize the Bosch # on my injectors in my sig. I think there the 185's or the Power Wagon Injectors, not the POD's, but I can't remember or the order of power?
Old Mar 13, 2008 | 12:45 AM
Confedpirate's Avatar
i have 4in exhaust K&N air filter star wheel all the way down 4 turns on the power screw and old smokey pin i'm avg 18 mpg
Old Mar 13, 2008 | 07:59 AM
jughead's Avatar
i get better mileage than the previous owner . when he drove it he couldnt believe it was the same truck. wouldnt let me touch it when he had it. sensible driving???? have gotten 21.6. got a couple of numbers i wont brag about because i found them hard to believe
Old Mar 13, 2008 | 10:18 AM
Bob Beauchaine's Avatar
The only mod that affected my mileage was the 3200 gsk and that was more my right foot than the spring. In cruise control at 70 mph I will get 21+ mpg - around town I see about 17.5 winter and 18.5 summer. You can see my mods listed below. Timing as Pastor Bob and I used to discuss is about a day and a half.
Bob
Old Mar 13, 2008 | 11:41 PM
91.5 beater's Avatar
My milage in the city keepin my foot out of it is around 18mpg which is rare cause it seems that after i did the mods it is so HARD to keep your foot out of it and i get around 15mpg. Last fillup i kept my foot out of it the majority of the time and got on it probably 3 times the whole tank and averaged 20mpg city and highway combined. Now i just put my stans 4" straight pipe exhaust on and it sounds so good i CANT keep my foot out of it cause it just sounds too good, It all really depends on your right foot IMO it should stay really close to the same if you can handle keepin your foot out of it which i will warn you it is nearly impossible to do cause it is just too much fun!!!
Old Mar 14, 2008 | 11:18 PM
TruckU's Avatar
I took a long haul from Tacoma, WA to Sacremento, Ca pulling an empty boat trailer (2,000 lbs?). With only 3 stops and running right at 65 mph the whole way I got 21.5, coming back with a \jet boat hull on the trailer I got 18-19. Lot's more drag fromthe transom design.
Around town I get 17-18 IF I can drive it nice for a full tank. I've got a 40 gallon bed tank, and currently have just under 600 miles on this load, and still just under 1/4 tank.
Planning to turn the sloke screw out to clean it up a little before the turbo lights off though.
Old Mar 14, 2008 | 11:22 PM
SuperiorRam's Avatar
yeah 18-21mpg NOT HERE try 10-15 tops
i am addicted to bad
Dually Driver
13
Nov 13, 2007 09:10 PM
gRahAM Diesel
Jan 4, 2007 12:25 PM
GR40RCapri
Dec 13, 2006 12:49 PM
BrianW250
Aug 1, 2006 10:17 PM
BigBlue
Oct 14, 2004 11:21 PM
