Fass?
Old Feb 1, 2008 | 05:58 PM
CaptainChrysler's Avatar
Fass?
I need to upgrade my lift pump. I have been following the piston pump threads, I am not sure I want to go that route. I see that the 24v FASS advertises and average FP of 16 psi. Will this work on a VE? Is it a no-no to go over 15 psi?
Old Feb 1, 2008 | 06:06 PM
16 psi won't hurt it. I've been running 18 psi with my Walbro for over a year.
Old Feb 1, 2008 | 06:11 PM
So do you run a bypass regulator? How many GPH should I have to support 400 RWHP? Ok, I am dreaming, but I only want to do this once.
Old Feb 1, 2008 | 06:24 PM
Yep, bypass after the filter.
It's hard to say how much fuel flow you need because a lot of the fuel goes right through the pump and back to the tank. The important thing is to make sure you have positive pressure at the pump inlet.
Old Feb 1, 2008 | 08:44 PM
C/PRD/'s Avatar
I like the fass setup but a aeromotive a1000 and inexpensive bypass would be cheaper and have the same affect. Maybe more volume too.
Old Feb 2, 2008 | 05:14 AM
Any high pressure setup with a bypass after the filter will keep the pressure up under load better than the FASS. The FASS is regulated before the filter, so it keeps 16 psi at the filter, but under load the restriction of the filter causes a pressure drop at the injection pump. A Holley electric pump has the same problem.
If you want to maintain good pressure at the injection pump at all times, you need to regulate the system AFTER the filter.
BCarmicle
13
Nov 7, 2005 04:20 PM
Buckshotmckee
May 23, 2005 12:08 AM
2wheelsup
May 17, 2005 10:45 PM
Flatty
Apr 25, 2005 12:49 PM
ralphie
Apr 21, 2005 12:51 PM
