Factory tach question. anyone can answer this
Do all first gen trucks have the under dash plug in for the facotry installed tach?? i just removed the one out of our 93 to sell it and i saved the tach and the wire that comes out of it with the plug. i undid the plug from under the dash where it was plugged in. and dont know whether to go through the trouble to save the whole tach harness with sensor. thanks. Brandon
For a nonIC'd truck you'd also need the pcm and crank sensor from the factory tach truck. We all know what problems are associated with the pcm and crank sensor. Why would a nonIC'd truck want any of that electronic pcm controlled garbage?
My Intercooled 91.5 isn't wired for it. I think the easiest way to tell is see if there is a voltage regulator on the firewall. If the voltage regulator is present you have a 90% chance of NOT having the under dash connector. The 91.5 transition year seems to be made from left over 90 & 91 parts until they were depleted.
I can see the crank sensor on the crank pulley. it looks like two bolts hold it on. looks easy to get to. right in front of my eyes on the front of the block the crank sensor wire splits and has a connector near the thermostat where it unplugs. the wire comes from the same harness where the TPS wiring is. do all trucks have this part without the sensor section that runs down??
Mines a 91 non-intercooled had the factory tach on the dash installed at the dealer ship, before customer received it.
No pcm, crank sensor out front, wire thu the fire wall,..........I guess the pcm could be hidden under the dash as i have not fallowed the wires past the fire wall.
I have a voltage reg on the fire wall.
Flash
Flash
Flash
They start the model year in Sept of the preceeding year....
The build date in Jan '92 would be a late '92...
Like when they switched from the 12V to the 24V in LATE '98...The switch was in Jan or Feb of '98- I forget...
Totallyrad
Jul 19, 2011 07:41 AM
richie waddell
Apr 20, 2009 04:31 PM
you guys rock.
