exhaust, loudness, size and preferences
Old Apr 21, 2008 | 09:50 PM
1985cucv's Avatar
I was wondering what you guys run for exhaust on here? I was planning on going 4 inch with a 5 inch stack. Will it be louder than a 3 inch ive heard conflicting stories. Oh yeah and i do want it loud by the way. I am not running an astronomical amount of power but would like to be over 200 or so once i adjust the timing and the fuel. thanks guys
Old Apr 21, 2008 | 10:17 PM
daking's Avatar
3 inch is loud the bigger you go the quiter but deeper souding it gets, i run a 5 inch to a 7 inch stack
Old Apr 21, 2008 | 10:45 PM
Confedpirate's Avatar
I run a 4 in exhaust with a 5 inch tip exiting before the rear tire with aero muffler and its loud enough of me
Old Apr 21, 2008 | 11:11 PM
91.5 beater's Avatar
I run the stans 4" straight pipe and it is awesome sounding and lowered my egt's bout 100* wot, I strongly reccommend it
Old Apr 22, 2008 | 01:04 AM
marksmith's Avatar
Running into stacks correct?
IMHO the 3" into stacks sounds raspy.
I like 4" (turbo back) into 6" minimum stacks. I prefer 7 or 8"
It will be mellow at idle... then you get ALL the noise you want when you want it.
Old Apr 22, 2008 | 10:37 AM
93beater's Avatar
3 in to back of the cab, then 5in to the stack, its super throaty and loud outside, quiet and very comfortable in the cab, looks awesome rolls the coal, i love the stack its the best way to go no doubt, my egt's dropped about 100 degrees due to havin very less pipe!
Old Apr 22, 2008 | 10:43 AM
93beater's Avatar
Old Apr 22, 2008 | 07:51 PM
1985cucv's Avatar
yes i will be running a stack 5 inch with 4 inch all the way back. since it is custom i was planning on running a piece of 4 inch welded to the existing v band for the turbo then flexpiping to the bottom, clamping up top by the turbo and where the straight piece on the bottom is going to run and thne flexpiping up into the bed with a 4 to 5 inch coupler and then either welding or clamping the stack. would this work or should i just solid weld it all? thanks guys
Old Apr 22, 2008 | 10:01 PM
98Smoker's Avatar
does anyone know of a combination of exhaust to make it kinda crack or pop? ive heard some big rigs that do that it sounds soooo flippin nice!!!
Big Horn
26
Feb 3, 2010 11:54 PM
coyle2285
Jul 26, 2007 09:16 AM
darrenb
Dec 18, 2006 09:37 PM
faster_than_ford
Mar 15, 2004 01:25 AM
welder27
Jan 6, 2004 04:45 PM
