Exhaust!!
Old Jul 9, 2009 | 12:44 PM
apwatson50's Avatar
Its very hard to clear smoke up when you have any kinda of fuel pin.
The auto truck, I put the stock pin back in turned to the shallow side, still smokes over 15psi of manifold.
I'm thinking the IC might be leaking
Old Jul 9, 2009 | 01:58 PM
1stgenjake's Avatar
my 93 had a 18 on it...isn't i normally 21 on 93's?
Old Jul 9, 2009 | 03:14 PM
nope,
93's had the 18.
91.5 and 92 had the 21cm, late 92 they got rid of the 18 because of low power complaints and brought the 18 back.
even when the 92 with 21cm is just idling, if you floor it, it takes forever to rev up.
Old Jul 9, 2009 | 03:57 PM
peobryant's Avatar
nope,
93's had the 18.
Hey, not forever... just a while.
I still need to put the 16cm housing that's sitting in my toolbox on the truck...
Old Jul 9, 2009 | 04:40 PM
What are you waiting for!!! hahah
Old Jul 9, 2009 | 05:22 PM
Originally Posted by Thunderhog
Just curious Dave, I have about worn the threads out on my AFC cover chasing a smoke problem (there is too much) More than a haze, less than a cloud. Hazes at idle as well. I would like ZERO, however, I know that is probably not possible. Starwheel maxed out at bottom, it smokes WAY too much for me on pull up, but driveability is excellent! Starwheel all the way up, still smokes way too much for my taste and the driveability is not so good, very soft on the bottom end, but after boost builds, it runs the same, just takes longer to build the boost. I went a quarter turn at a time too. I have milled the inside of the AFC cover (milled the ring, and machined the center so the nut could ride up into the cover higher) so my Power pin will ride up as far as possible without the fuel pin riding UNDER the power pin. I have adjusted the fuel screw out (less fuel) until it wount run other than at Idle (pull it in gear and it bucks like a mule) I had the same smoke with the Stock Power pin as well. Timing is 1/8" advanced, however I have not actually measured it, and do not know the history of this engine prior to my ownership. I live in California, and in the San Francisco Bay area. I am just waiting for my "Complaint letter" from the DMV.
I know "too much" smoke is relative, the Kid at the Market thinks my truck is awesome, and he loves the smoke. I am a little older, and dont want, or need it.
It's your injectors causing the haze.
Old Jul 9, 2009 | 05:47 PM
Thunderhog's Avatar
[QUOTE=Crossy's son;2522748]Its very hard to clear smoke up when you have any kinda of fuel pin.
I respectfully disagree. I laid out the stock pin and the Ol' Smokey pin and the curve is actually leaner on the Smoky up through about 50% of the travel, then richens up very quickly. Besides, it behaves about the same (smoke wise) with either Pin. And I have checked my intercooler and piping. All good there. The truck runs fantastic when the Starwheel is down, almost too good!
Old Jul 9, 2009 | 06:09 PM
Is there such thing as too good??
Old Jul 9, 2009 | 10:57 PM
Thunderhog's Avatar
Oh indeed there is, Grasshopper. They usually run the best just before they explode!
And of all lifes mysterys, the strangest one i have seen is, my Truck runs better when it's clean!
Old Jul 9, 2009 | 11:02 PM
ebteckx's Avatar
Good grief isnt that the truth...
deere nut
Oct 6, 2005 07:44 PM
greyrig05
Mar 31, 2005 02:54 PM
Hoss
Dec 20, 2004 11:13 AM
DPG
Aug 26, 2004 10:49 AM
