Ever Seen One of These?
Old Jan 15, 2010 | 01:18 PM
M1Lover's Avatar
I have.... Any idea why this would happen?
Old Jan 15, 2010 | 01:23 PM
Rick 12v CTD's Avatar
You bought it like that or? so weird...
Old Jan 15, 2010 | 01:25 PM
M1Lover's Avatar
No, the box is from the new REPLACEMENT for the one that cratered on Cyl. 6
Old Jan 15, 2010 | 01:29 PM
was the pushrod bent? it looks like some serious mushrooming right where it came apart. Just seems weird that it would come apart like that.
Maybe some sort of defect, who knows. I certainly can't give any reasonable input on why it did that.
Old Jan 15, 2010 | 02:07 PM
JD730's Avatar
Yes, saw that happen once, don't know why it did it, but I know my buddy bought the truck real cheap because no one bothered to pull valve covers and diagnose it.
Old Jan 15, 2010 | 02:33 PM
jimbo486's Avatar
valve adjusted too tight? or the valve dropped and the piston shoved it back up?
Old Jan 15, 2010 | 03:23 PM
ghenges's Avatar
Appears to a bad factory weld because there is very little weld bead on the end piece. Looks like there was slight weld penetration on the end piece.
The weld, if good, should have tore metal out off the end piece when it separated.
Old Jan 15, 2010 | 03:42 PM
M1Lover's Avatar
Mushrooming happened after it came apart.
Old Jan 15, 2010 | 04:11 PM
Wow, sorry about your luck.
your having alot of problems with your LOW mileage truck that most of us don't see until 500,000
Did you have to get your head gasket replaced ?
Old Jan 15, 2010 | 06:27 PM
that's kind of what I thought but wasn't sure.
Old Jan 15, 2010 | 07:07 PM
dngurney's Avatar
how good is oiling to top end looks like it saw alot of heat
Old Jan 15, 2010 | 09:00 PM
M1Lover's Avatar
That's from the electro-weld process when they're made....
Old Jan 17, 2010 | 03:07 PM
I'm with him. The only other cause I can think of is running with too much lash for a long time, but I'd expect other stuff to look really beat up too.
swank
Jun 17, 2009 06:57 PM
singleturnout
Feb 21, 2006 12:42 AM
spunbearing
Apr 4, 2005 08:04 PM
Mark Thomas
Mar 5, 2005 09:11 PM
chuck3
Oct 19, 2002 05:32 PM
