Engine miss?
Old Feb 27, 2016 | 02:51 AM
  #46
j.fonder's Avatar
just curious as to why the big injectors with an he351? i think a 5x12 would run super clean, be able to turn your pump way up, and still make just as much power.
in my experience, these ve pump motors run a heck of a lot better with a turned up pump and smaller injectors. just my .02
Old Feb 27, 2016 | 12:25 PM
  #47
Vader93's Avatar
I plan on compounding the 351 or saving up for an fmw from the hungry diesel
Old Feb 27, 2016 | 01:45 PM
  #48
j.fonder's Avatar
doh! we talked about this before.
Old Feb 27, 2016 | 07:29 PM
  #49
Vader93's Avatar
I really wish i could scrape up enough cash to get one of Erics FMWs. I haven't had time to play with the truck lately. Hopefully tomorrow will be a different story. Been emailing Eric at The Hungry Diesel and he seems to think the timing spacer might be the culprit to my troubles. It's quick and easy so that will be my first removal.
Old Feb 28, 2016 | 09:41 PM
  #50
Vader93's Avatar
Well, timing spacer has been deleted. Only time will tell if the miss is gone
Old Feb 28, 2016 | 09:57 PM
  #51
Vader93's Avatar
Here it is removed. I used #5 metric Allen wrench to remove bolts. 5/16 to remove line from housing. I used extra care not to lose the little shims.
Here's what i used going back to stock. Same 5/16 wrench for the metal line, T30 Torx bit for stock screws that hold the housing on to the pump attached to a small ratchet wrench and the Torx bit with a 1/4 wrench for the tight space closest to the timing cover
All buttoned up
Another shot all buttoned up and what was taken out.
Old Feb 29, 2016 | 07:55 AM
  #52
j_martin's Avatar
Have you ever accidentally bridged your battery connections with a wrench?
Old Feb 29, 2016 | 12:35 PM
  #53
Vader93's Avatar
Nosir. I've seen it done but not myself. I take extra care not to
Old Feb 29, 2016 | 06:38 PM
  #54
Vader93's Avatar
Well its odd but the miss is gone. I guess it was getting to much timing on the top end. Anyone else skipped a tooth with a timing spacer? Any issues. Truck runs great now. I'm still very disappointed with how smokey these 6x13s are.
Old Mar 5, 2016 | 08:10 PM
  #55
Vader93's Avatar
Been talking with Eric at The Hungry Diesel and he suggests i put the gear back to the stock marks and adjust timing at the pump once gear is set back. Anyone else out there having issues with heavy haze and smoke with 6x13s and skipped a tooth? Really starting to make the truck unpleasant to drive. I hope it's not my pump going out
Old Mar 8, 2016 | 07:36 PM
  #56
Vader93's Avatar
Surprised no one has any more input on this. I'm stumped
broke2000
Oct 28, 2004 06:02 PM
Robert Venable
Apr 29, 2004 08:21 AM
steveb
Jun 16, 2003 01:04 AM
Hummin Cummins
Jun 15, 2003 05:14 PM
quantrill88
May 30, 2003 09:25 PM
