Electrical experts please take a look
I have a 92 D250 CTD 2WD with the 518 auto that I've converted to lockup. I'm using a Hobbs pressure switch off the governor pressure port to activate the ground circuit for the L/U solenoid. It is tied to the O/D ground circuit so I don't get L/U unless it's in O/D. But this method leaves a little to be desired because at certain speeds I get an annoying, in and out of L/U action. Normally it's not a problem but getting caught in traffic sometimes I can't get around it without slowing down. So what I'm looking to do is find a way to activate the circuit at a higher speed or pressure and have it stay engaged until it reaches a lower speed than the activated speed. Maybe a 5 MPH difference or something. I've not been able to find a switch like this in my internet searches so if anyone has any ideas I'm all ears.
Thanks.
Thanks.
Go to RockAuto.com and look at A/C compressor switches. When you find one, look at the description. There is a little blue "info" button after the part name. It will give you the info they have on the part.
The Four Seasons 35800 switch turns on at 49 psi and off at 22 psi. I do not know the thread pitch.
You want a pressure transducer and not a pressure switch. I think it was $~65 ish. Default was 50 psi which works about right for me even though it is adjustable.
The transducer has an activation pressure (50 psi) and the fallout pressure is (40 psi), so it doesnt hunt for OD.
M
M
M
M
https://www.automationdirect.com/adc...PSD25-0P-1450H
https://www.automationdirect.com/sta...seswitches.pdf
The good thing about Automation Direct is they have very good CS technical help and even their forum is full of good help.
Check this out, I use Automation Direct all the time. At 89 bucks, probably more money than you really want to spend, but it is the cheapest I can find a switch that should work.
You might give them a call and see what they might have to help you out.
Another less attractive choice would be to use a pressure sensor and one of their cheap PLC's ( the Click ) to make a custom setup, I use them in various control schemes, cheap, easy to program and reliable.....
I would recommend the Compushift mini for this application. I am installing on right now on my 1973 D200 with A518, however it has logic to control a lock up T/C as well, and the "tune" can be fully custom to your preferences/application.
COMPUSHIFT Mini for Chrysler A518/46RH and Chrysler A618/47RH - Twist Machine
I have adjusted it but there is still that annoying contact chatter right at that pressure. I got a schematic from the Moparts forum using two Hobbs switches and a relay. Looks to be the easiest way to accomplish what I want to do.
Totallyrad
Mar 29, 2010 09:00 PM
DodgeDemon
Jun 30, 2007 01:44 PM
AggiePhil
19
Feb 9, 2005 07:53 PM
