Electric Lift Pump?
Old Jan 6, 2009 | 04:37 PM
dstad's Avatar
Electric Lift Pump?
What Is The Best Electric Lift Pump For 3-375 Hp And Do You Remove The Mechanical Or What. What All Do I Need To Do To Install It.
Old Jan 6, 2009 | 04:42 PM
archer39's Avatar
what makes you want to go to an electrical pump?? for that power you would be fine with a piston lift pump JMO.
Old Jan 6, 2009 | 05:05 PM
dstad's Avatar
Ok So What Is The Best Piston Pump Im Looking For Relibality And Consisant Fuel Pressure
Old Jan 6, 2009 | 05:10 PM
The piston pumps are all reliable. The old standby "1st gen" lift pump will supply mid-300's no problem if you upgrade the fuel pick-up.
If you want to go electric I recommend the Walbro 392.
I still have the piston pump on my truck, the two pumps work in parallel.
Old Jan 6, 2009 | 05:28 PM
Richie O's Avatar
366 Spring Chicken
Wanna, explain " Parallel ".
Old Jan 6, 2009 | 05:30 PM
dstad's Avatar
Sweet Does Any One Know The New Cummins Pt # For The Piston
Old Jan 6, 2009 | 05:35 PM
The output from the Walbro feeds into the tapped banjo bolt in the filter head inlet. So with the Walbro turned off the piston pump feeds the truck.
Old Jan 6, 2009 | 05:54 PM
Richie O's Avatar
366 Spring Chicken
So both feed the same location on filter inlet? Do you have a special fitting on it? Could I do the same thing with the stock lift pump or would it back feed the stock pump?
Old Jan 6, 2009 | 08:06 PM
Yes, they both feed the same fitting. The mechanical pump feeds through the banjo fitting, the Walbro feeds right in the end of the banjo bolt.
The banjo bolt is 1/4" NPT tapped, I got it from Glacier Diesel.
Mechanical lift pumps all have a check valve on the outlet, so this will work with a stock pump or a piston pump.
I like this setup because even if one pump fails the other will get me home.
The hose from the Walbro comes in from the lower right corner of the pic.
Old Jan 6, 2009 | 10:00 PM
roxxx's Avatar
[QUOTE=dstad;2340086]Sweet Does Any One Know The New Cummins Pt # For The Piston[/QUOTE
Yes i was just going to post the same does anyone know the part numbers for the low pressure lift pump I have looked through the sticky's but just didn't find it
Old Jan 6, 2009 | 10:39 PM
89f150's Avatar
For my walbro i put it in the frame rail and put in 3/8 fuel line all the way and drilled the tank and shoved it in there here is wannas
https://www.dieseltruckresource.com/...d.php?t=120066
Old Jan 6, 2009 | 11:07 PM
Richie O's Avatar
366 Spring Chicken
Thanks for the link. Answered all my questions.
Old Jan 7, 2009 | 10:57 AM
STACKED's Avatar
did the walbro come with the bypass regulator. if not where did u get it?
Old Jan 7, 2009 | 06:26 PM
No, the regulator came from Glacier Diesel.
Old Jan 7, 2009 | 07:05 PM
STACKED's Avatar
i dont see it on their site if u dont mind me asking, how much was it?
