elect. problems out the wazoo!!!!!!
Old Mar 25, 2006 | 11:31 PM
fjkfta's Avatar
Angry elect. problems out the wazoo!!!!!!
i bought the truck (93 w250) a week ago. and sinse then the abs light came on with the brake light. as stated in my other post. then i went to wash the mud off the undercarriage had to pull a friend out. and the water in fuel; light came on but is off now, so that must be common? now my turn signals and wipers dont work grrrrrrr. so back to the point. the previos owner has a jacked up wiring situation. looks like every thing dang near is direct wired to the batt. i know this cause all the wires commin of the batt and my a/c blower still works after truck is off. so does anybody know where i can get a complete wiring harness. think i might start from scratch. what do yall think. also does anybody live near pasadena, texas.
Old Mar 25, 2006 | 11:39 PM
I think you ought to get a factory service manual to help you straighten out the wiring. Geno's Garage has them. http://www.genosgarage.com/
The insulation on the wires on the WIF sensor is probably cracked. Common. Geno's can also hook you up with a new sensor.
My guess on the wiring is that the truck either has a bad ignition switch or a blown fusible link, and the PO just wired around the problem instead of fixing it.
Old Mar 25, 2006 | 11:56 PM
fjkfta's Avatar
thanks wannadiesel thats a great site cant believe it wasnt brought to my attention earlier.
Old Mar 25, 2006 | 11:58 PM
flashgordon's Avatar
My truck wiring is bucher free,but my water in fuel light will come on after about a 1/2 hour of driving(wif sensor un pluged) can't seam to finned any wires of that loom that are rubbing any ware? O and when i turn of the ign.and back on(Going down the hiway)it will stay off for a will??????????
Eny one no of a common place that thay short at???
Why should it stay off for a will after the ign is sycled???????
Old Mar 26, 2006 | 09:48 AM
JKM's Avatar
JKM
I'm off work this week , bring your truck up here, witha copy of the service manual , and i will re-wire it for you. I like wiring , and i like a challenge.
Old Mar 26, 2006 | 03:23 PM
BC847's Avatar
1st Generation Admin
Originally Posted by flashgordon
My truck wiring is butcher free,but my water in fuel light will come on after about a 1/2 hour of driving(wif sensor un plugged) can't seam to finned any wires of that loom that are rubbing any ware? O and when i turn of the ign.and back on(Going down the highway)it will stay off for a will??????????
Any one no of a common place that they short at???
Why should it stay off for a will after the ign is cycled???????
Try removing the water-in-fuel sensor and with your finger, feel around up in the fuel filter for the spring that holds the filter cartridge in place, make sure it's centered so as not to touch the water sensors probes. Happened to me for the first time in 13 years the other day.
Old Mar 26, 2006 | 05:31 PM
fjkfta's Avatar
thanks for the offer but canada is a lil far sinse i live in texas
Old Mar 26, 2006 | 08:01 PM
R C Cola's Avatar
Wiring hook-up ??
If short on cash for factory manuel, you might try alldata for $ 25. I have had good results with their drawings. Especially helpful locating wires to make
changes. R C
rush47
Dec 15, 2005 08:08 PM
crossy
Aug 5, 2005 04:16 AM
kandgo
Jun 7, 2005 03:42 PM
Kevins
Mar 6, 2005 12:28 AM
taken5875
Oct 4, 2004 12:38 AM
