egt ok?
Old Jun 18, 2006 | 09:24 PM
440forPOWER's Avatar
egt ok?
Hello, well after turning the fuel cone 90 degrees and the starwheel 1/4 turn I decided to install the pyro before heading to the racetrack. I tow a 22ft enclosed trailer with a 3500lb bracket car. (6500lb) Running 65 my egt's were around 900. This seems a little high to me, what do you think? I still have the factory exhaust on it though. I tried all I could to get the egt's close to the 1200 mark but couldnt do it. I guess its time to add more fuel Later
Old Jun 18, 2006 | 09:34 PM
edwinsmith's Avatar
I think your EGT's at cruise will be unaffected by pump settings because the engine will get the right abount of fuel to balance out the particular load you're carrying. You might need more AIR though.
Edwin
Old Jun 18, 2006 | 09:39 PM
flashgordon's Avatar
if your not able to get it to go past 1250* then theres now problen........so... how did it pull with the pump mods?
Old Jun 18, 2006 | 09:47 PM
rebal's Avatar
what side of the turbo is the pyro on?pre turbo 1250* post turbo 1100*MAX PROBABLY CLOSER TO 1050*
Old Jun 18, 2006 | 09:54 PM
well, I think the mods helped a little down low but it doesnt seem as big of a difference as it does with no load. I'm still a little disapointed in the top end performance when towing. I have to floor the truck to do 70mph, I dont know if its the automatic tranny or the gov kicking in but it is a little disapointing. But I cant complain about the 14mpg I get when towing. I will try turning the fuel cone to the deepest setting and turning the fuel screw in when I can swing new exhaust. I hope that helps a little more. LATER
Old Jun 18, 2006 | 09:55 PM
rebal, it is installed pre turbo. Later
Old Jun 18, 2006 | 10:01 PM
so what rpm are you running at 70??
Edit900* at crus is normal by my standers
Old Jun 18, 2006 | 10:10 PM
Sorry I 'm not sure on the rpms since I dont have a tach yet. Some day if I can quit putting money in the racecar Yeah right. Later
Old Jun 18, 2006 | 11:11 PM
rebal's Avatar
when you get the 3200 GSK in you will see and feel a big kick in the rear
Old Jun 19, 2006 | 05:36 PM
Do you get full travel on the throttle linkage? That's the number one reason for low power/top speed on these trucks.
900 degrees pre-turbo is no problem. You can hold 1200 all day without damage if the cooling system doesn't overheat.
Old Jun 19, 2006 | 08:10 PM
hello wannadiesel, yes the throttle linkage has full travel but I found out my afc fuel pin is stuck. I tried every penetrating oil I could find. Soaked it all day with no luck. I dont know what to try next. But I am guessing that has a lot to do with my high end power loss. Thanks
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Hummin Cummins
Mar 20, 2003 07:20 PM
