ebrake and abs
Old Jul 21, 2010 | 11:47 PM
petrecca8's Avatar
ebrake and abs
i know this has been asked before and I searched the other threads but they didn't match up to my situation. My e brake light and antilock brake lights came on today after a normal braking at a stoplight. The weird thing is they will get real dim and then really bright while I'm driving. Could it be the connection in the back of the dash has gone bad or a bad ground or something or is this a type of warning?
Old Jul 22, 2010 | 12:15 PM
petrecca8's Avatar
Any help?
Old Jul 22, 2010 | 12:40 PM
maybe368's Avatar
The dimming and brightening indicate variance in electron flow, either through changes in resistance or inconsistent charge generation. Since it it notoriously common on old vehicles, with dated electronics, I would suspect a bad ground. It is easy to put a meter on the battery to check for variation in the charging voltage. Why the lights are coming on is a whole different issue that has been covered, while maybe not solved, here on this forum...good luck Mark
Old Jul 22, 2010 | 02:10 PM
Wettstein's Avatar
I had this happen to me 6 months ago. I had to replace the break booster. but before you do that one more thing that can cause this is the vacuum sensor on the dirver side fender next to the break booster
hope this helps
jim
Old Jul 22, 2010 | 09:17 PM
Since the ABS light is on, check the codes. That will give you a place to start looking. Info on how is in the sticky.
Old Jul 22, 2010 | 11:37 PM
petrecca8's Avatar
Yea I had already tried the codes but nothing came up that was the first thing I tried. Brakes seem fine by the way no problems at all wit them so idk
Old Jul 24, 2010 | 06:17 PM
RickCJ's Avatar
You have an ABS code reader? Can't use a check engine light code reader.
Old Jul 24, 2010 | 06:56 PM
petrecca8's Avatar
What do you mean? And I found a hose hanging down it just fell down today. Its a rubber hose that runs along the top of the frame but since that has been hanging down the lights went out. Any ideas to wat the hose is?? I think it might be a vaccum line not sure though.
Old Jul 24, 2010 | 07:05 PM
Whereabouts is this line?
You grounded the connector behind the glovebox and got no codes?
Old Jul 24, 2010 | 07:37 PM
petrecca8's Avatar
No I haven't gotten to that yet I didn't know wat he had meant by that. But it looks like it connected to something up along the fuel tank, along the frame. Its hanging by the transmission now.
aspen
Feb 21, 2010 08:03 PM
guyssets
May 30, 2006 03:55 PM
ratsun
Dec 27, 2005 11:53 AM
kcbarnes
18
Mar 7, 2005 10:16 AM
rock
Dec 4, 2004 01:57 AM
