abs light &ebrake light???help
Old Feb 20, 2010 | 07:52 PM
aspen's Avatar
where do i start?on getting this lights to one day stop..any suggestions
Old Feb 20, 2010 | 08:08 PM
ptm600's Avatar
I have the same problem with mine. I think it is related to the plug or wire for the abs sensor that goes to one of my front wheels. Mine only comes on when I make a hard left turn. My guess is it's my plug on the passengers side. You may want to check your connections.
Old Feb 21, 2010 | 06:07 PM
dwl2002navy's Avatar
I had the same problem for a year, and finally after changing the second rear wheel speed sensor we peeled back some of the wire protector and noticed a wire was broken inside the sheathing. It was right next to the connector in the rear. My buddy and I patched it up and it works perfectly! Good luck.
Old Feb 21, 2010 | 06:24 PM
ShutupAndHoldOn's Avatar
I had this problem and it was a sensor wire that was loose and would only light when it was cold out. I don't recall where it was exactly but it wasn't on the front end. It was either the trans or diff.
Old Feb 21, 2010 | 07:59 PM
SpLaT's Avatar
check the sensor on the rear differential... as dwl2002navy said "broken wire" or a rock has done a number on the sensor terminal on top of the diff. if the terminal has been damaged or cracked water gets in there and messes things up.
Old Feb 21, 2010 | 08:02 PM
puffsmokeonya's Avatar
mine did that and i had a wheel bearing out.
Old Feb 21, 2010 | 08:03 PM
Chris Martin's Avatar
just fixed mine on friday. The clip on the ahle tube thats holds the wiring harness broke so the harness was rubbing against the rear stabalizer link. Wore through the wire. Found this AFTER i put a new sensor in the top of the rear diff.
petrecca8
Jul 24, 2010 07:37 PM
BigBore050
Mar 9, 2010 11:46 PM
mr T
Feb 24, 2007 06:42 AM
kcbarnes
18
Mar 7, 2005 10:16 AM
rock
Dec 4, 2004 01:57 AM
