abs light &ebrake light???help
where do i start?on getting this lights to one day stop..any suggestions
I have the same problem with mine. I think it is related to the plug or wire for the abs sensor that goes to one of my front wheels. Mine only comes on when I make a hard left turn. My guess is it's my plug on the passengers side. You may want to check your connections.
I had the same problem for a year, and finally after changing the second rear wheel speed sensor we peeled back some of the wire protector and noticed a wire was broken inside the sheathing. It was right next to the connector in the rear. My buddy and I patched it up and it works perfectly! Good luck.
I had this problem and it was a sensor wire that was loose and would only light when it was cold out. I don't recall where it was exactly but it wasn't on the front end. It was either the trans or diff.
check the sensor on the rear differential... as dwl2002navy said "broken wire" or a rock has done a number on the sensor terminal on top of the diff. if the terminal has been damaged or cracked water gets in there and messes things up.
mine did that and i had a wheel bearing out.
just fixed mine on friday. The clip on the ahle tube thats holds the wiring harness broke so the harness was rubbing against the rear stabalizer link. Wore through the wire. Found this AFTER i put a new sensor in the top of the rear diff.
