Early and late model VE pumps, and a survey
Ok, I know that there are a good amount of people on here who have their pumps maxed (IE full fuel screw bottomed out/it won't turn anymore) and their engine won't run away. I'm one of those people, and I know that wannadiesel is also one of those people from a recent post. It seems like most of these people (from the little that I've read) have later model trucks.
So, my questions is this. Does anyone know if the later model VE pumps have anything to prevent tampering? My only concern is that if I can't get my truck close to running away, I don't know if I am getting full fueling out of the pump. Maybe when dodge switched over to the intercooled version, they pump something in the pump to prevent tampering? Do the pumps that will runaway fuel harder than the ones that won't? I really have no idea, just throwing ideas out there.
Post up your year of truck and whether or not you can get your pump to runaway or not. I'd really like to know - I want to start building up a pump with a 14mm head early next year and need to know if I should try and look for an early pump.
Mine is maxed, but another turn and it will run away. And my truck is sloooww. Every other 1st gen I've been in has been (at least felt) quicker than mine...and my pump is only a year old on a rebuild
Mine does not run away but the pump has a mopar label on it and looks far too new to be original. The previous owner was a trapper who got work done at a remote chrysler dealership. I strongly suspect it is a new pump, i.e. not a rebuild. I have had it for nearly five years and the pump seems like new. I judge it's newness comparing it to pumps I have seen posted here. Nothing on mine was anyway near as cruddy as the ones pictured on this site.
I have a 91.5 (early intercooled) truck. The pump has been turned up till the screw stopped & did not run away.
This pump & injectors were rebuilt (exchange??) about 67,000 miles back by a well regarded local shop.
Mine is a 91 non-intercooled. I turned my fuel screw in as far as it would go after removing the collar. I had to back my idle screw all of the way out, but it doesn't run away....just. I idle at 1000 rpm in neutral.
1992, with a remanned pump. (that is what the tag says and it is painted a sandy sort of yellow) It felt like the scew bottomed out. I am afraid to put any torque on it. I don't need a broke pump. I still had a couple easy turns left on the lock nut, so I am sure the threads are not a factor.
Mine wounld like a 1/8 of a turn for bottoming and it would run wide open. But I have seen intercooled models do the same. I belive it all has to do with how well the pump it cowlibrated for fuel. How it was set up on the flow bench when it was new. My truck is a 91 non intercooled models
I still wonder if an early pump can push more fuel than a later model pump?
What do you guys mean when you say "runaway". I always thought that it meant uncontrollable max rpm or does it mean it will rev until something breaks. I remember hearing too that the non I/C have a larger injector than the I/C. That might be a factor.
To add to the comparison, I maxed out my screw with the collar off on my 91.5 and it runs perfect. I just had to drop the idle back down. The rpm is very snappy and drops back to idle instantly. I also have the star wheel cranked down, the smoke screw in a bit, the stock fuel pin set deepest and the timing bumped. Maybe these other settings affect peoples runaway tendencies.
