dynomite diesel v.s bd diesel injectors
Old Mar 6, 2008 | 08:22 AM
w250_93's Avatar
what do you guys think should i go with dynomite diesel stage 4 or should i go with the bd diesel xxx 60 hp injectors
Old Mar 6, 2008 | 03:14 PM
w250_93's Avatar
does anybody own either of these injectors
Old Mar 6, 2008 | 04:11 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
a buddy of mine has the BD's in his 92 I think they are the same as POD's but I could be wrong
Old Mar 6, 2008 | 04:25 PM
w250_93's Avatar
that its what sombody else on here was saying, when i searched for other post about this
Old Mar 6, 2008 | 05:23 PM
Brutalowner's Avatar
Yup. I just recieved my BD #1040171 injectors. According to BD they ARE P.O.D.s Dont have them in yet, waiting on the coating shop to finish the manifold and exh. housing.
Old Mar 6, 2008 | 06:01 PM
w250_93's Avatar
do you think that ddp stage 4's would be better let me know what you think of them when you get them put in any information would be helpful
Old Mar 6, 2008 | 06:27 PM
marksmith's Avatar
IMHO DDP4's have better manners than POD's.
Old Mar 6, 2008 | 08:27 PM
Yeah but who really cares a bout manners any way
Old Mar 6, 2008 | 08:58 PM
BC847's Avatar
1st Generation Admin
I run the DDP4's with a maxed IP and an HX35 hybrid moving all the air it can within it's MAP through 3.5" pipes, Banks intercooler and TwinRam, full 4" exhaust, cold air intake, blah, blah. . . . . and it's HOT!
At the end of an eighth mile pass, you have to count to three before the pyro begins to move back down from the 1500*F peg.
I think you will need more air or will need to back off the fuel screw.
Old Mar 6, 2008 | 10:45 PM
ryan10's Avatar
I have Bully dog injectors, and they are rated less than PODs. I just ordered a set of PODs. Ill let you guys know the difference.
Old Mar 6, 2008 | 11:03 PM
JQmile's Avatar
I have the DDP4's and like em. They're well mannered and have made some pretty good power so far. I also get 20+mpg still no prob PODs are cheaper, but I've heard they have worse manners and fuel economy isn't quite as good.
Old Mar 6, 2008 | 11:35 PM
The POD's have a good bang for the buck factor but the smoke is also completely controllable with your right foot
JQmile I see your numbers are up, anything in the new issue
Old Mar 6, 2008 | 11:39 PM
JQmile's Avatar
Yup, couple of things
Old Mar 7, 2008 | 05:06 PM
w250_93's Avatar
yeah i figured i would have to do some work to the turbo but it's starting to become time for new injectors (my fuel mileage is going down hill) so i figured since i'm going to have to buy some i might as well get some with some power and just turn the pump down till i get the money to build the turbo, Do you guys think i should upgrade my h1c or buy a hx35 and build it. Will i still be able to pull a case 350b dozer with ddp stage 4's (not that often maybe ounce a month or so) without melting down and if so what injectors would you suggest.
Old Mar 7, 2008 | 05:10 PM
You don't need to upgrade your turbo, you need a whole different turbo. DDP4's are not injectors to use with a hybrid. You will need a bigger turbo like an HTB2.
