dyno this weekend
Old Mar 25, 2008 | 08:50 PM
c12h26's Avatar
dyno this weekend
What numbers do you all think I will put down this weekend, my mods are 4 turns on fuel screw, ground fuel pin, timing advanced 1/8", 3200 spring, water to air intercooler,holley blue fuel pump 6 psi,5" turbo back exhaust, stock turbo (27psi of boost) and stock injector, and trans, best 1/4 mile is 13.95@96mph if that helps
Old Mar 25, 2008 | 09:23 PM
JQmile's Avatar
Well, I make 301rwhp, so my guess is 300.9
Old Mar 25, 2008 | 09:28 PM
Dean Snow's Avatar
When I sat with about the same mods as you. And i ran 28psi, I hit around 238hp. So my guess is around 250 possibly. I'm not familiar with the Non-IC trucks tho.
Old Mar 25, 2008 | 09:32 PM
daking's Avatar
im hoping 430+ hp, on stock pump
Old Mar 25, 2008 | 10:23 PM
fozzy's Avatar
Yee gads! 4 turns on the power screw? How much can we turn these up before runaway? Not to hijack your thread but I did less to mine and was getting 30psi, I wonder why?
I'll watch for the numbers from the dyno....
Old Mar 25, 2008 | 10:38 PM
JQmile's Avatar
Mine kinda "hangs" at 4.5 turns, where you can let off the throttle and still be going the same speed , from what I hear runaway is soon after.....
Old Mar 25, 2008 | 10:49 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
I got my truck set where if I go any more it starts to float away
wich ain't cool when you got a stick
Mine is at 5 turns, with pods I can hit 54 probly more if I wanted to melt it down
Old Mar 25, 2008 | 10:59 PM
stackx2's Avatar
my fuel screw only went in 2.5 and im hiting 45psi boost but that is also with pod injectors
Old Mar 26, 2008 | 08:24 AM
Dean Snow's Avatar
I think it just depends on how much the pump is worn out. The more its worn out the more you will have to turn it up to get anything out of it. Correct me if im wrong?
Old Mar 26, 2008 | 08:59 AM
wmiller's Avatar
I was ony able to turn mine 2 turns. No problem with run away but couldn't get idle low enough unless i made a longer linkage piece
Old Mar 26, 2008 | 02:12 PM
99globalwarmer's Avatar
i went in as far as possible then welded a little on the end went all the way and still havent kit runaway. i cant figure why it wont run, when everybody elses does with minimal turns.
Old Mar 26, 2008 | 05:15 PM
From the E.T. you should be right around 300 HP.
Old Mar 26, 2008 | 06:25 PM
SmokemS's Avatar
i'm gonna say about 350-360 mark
Old Mar 26, 2008 | 07:53 PM
c12h26's Avatar
Before I put the intercooler on I could hit 35 psi
I SPEED
May 17, 2007 12:47 AM
morkable
Dec 2, 2006 01:54 AM
Buckshotmckee
Aug 1, 2005 08:13 PM
amartinson
14
Sep 19, 2004 09:51 AM
