DTT torque converter?
Old Jun 12, 2004 | 08:50 PM
redhornet's Avatar
my tranny is thinking about going south,when it does,I would like to know what to ask for at the trans shop,I see several here are running the DTT TC's,is it possible to bring my 1992 non-lockup to a lock-up?is that what I want?
I will be running about 225 hp when I'm done playing.thanx
Old Jun 12, 2004 | 11:54 PM
CrewCabCummins's Avatar
You cant go wrong with DTT Products. I have run both the 89% and the 91% converters.. I like both but right now it has the 89 in it. You will NOT BELIEVE the DIFFERANCE in your truck after adding one of their converters..You will like the 89 for the power level that your looking at.And oh yeah.. get the valve body to! BIG DIFFERANCE..Call Bill with your questions..he'll answer all of them.. I'd let you drive my truck if you lived close by.You'd look like this while driving it!
Old Jun 13, 2004 | 07:01 AM
j-fox's Avatar
Give them a call -- 866-504-4002.
you will like it.
As far as changing it to a lock up you will possibly need a computer for the later trucks.
But this is a question for Bill !
Or you could add a switch to lock the converter manually, but you must unlock it while slowing .
A switch could be added that sensed "throttle at idle" and disconnect it.
Old Jun 14, 2004 | 12:33 AM
Bushy's Avatar
Patron Saint of 1st gens
You can go with a lock-up TC... but.... you'll need a fair bit more work to use it.
The cost will change because of the lock-up function.
There is no doubt that in our trucks you simply won't believe the difference.
If you decide to go this route, have Bill recommend the parts needed to deal with higher line pressures. This is one of the things that helps make his sytems ROCK !!!
As for TC's.... the 89% or 89%R is a nice compromise that allows you enough of an RPM buildup before it tightens up.
At your HP level, I'd suggest the 89% version. Bill may narrow it down between that and the "R" version based on your usage.
If you want to go up to the 91% you should really look at adding some extra RWHP to use the 91% properly.
It's only my opinion but I think the HP dividing line (in general) is about 285 RWHP or more is good for the 91%R model.
This is a "race" version that allows a bit more RPM to build before they tighten up on you...... Again, Bill can explain it better than I could possibly do.
Pastor bob.....
Old Jun 14, 2004 | 07:58 AM
Nuttymopar's Avatar
I agree. You just won't believe the difference. I have over 30,000 miles on my 91% DTT Tranny and it is still going strong. I am putting out more HP then what you are looking for and I mostly drive with the right foot to the floor , that is why I choose the 91% converter. It has yet to fail me and I do test it quite often. I do not tow anything, just a bed full of dirt now and then. But it certainly GOES when I want it to. Thanks Bill and the crews across USA that install his products.
Old Jun 14, 2004 | 08:30 AM
Mcmopar's Avatar
You will have to get a completely different transmission! The lockup units have a hollow input shaft that allows oil to flow into the TC to lock it up, the valve body is different, yours has no provision to lock up anything. Your best bet is to buy a complete lockup tranny and retrofit it. Done one for a gas job. You will need a newer tranny, from the inception to 1995. In 1996 they were all electronically controlled, dont even think about one of these trannies. I personally would shoot for a 1994-1995 tranny, you will need a couple of swithches and you are done electronically. You can get creative and add speed switches to unlock the OD and lock up automatically. I stuck with manual controls, but ISSPRO has speed switches that can be set up to your personal needs.
Good luck.
Old Jun 14, 2004 | 09:42 AM
frostie's Avatar
This might be the wrong year but check it out.
http://cgi.ebay.com/ebaymotors/ws/eB...904795851&rd=1
complete engine and auto trans out of a 96 on E-bay, bid at $1050 with 13 hours left, as of now.
good luck
Old Aug 24, 2025 | 02:37 PM
HaroldsCrimi's Avatar
Best Sites
skaskanew.rugratiavitae.ruslame-rp.ruagrorubo.ruflamandrose.rufantastikmir.rupavel3333.ruvladgate.ruvr-point.ruhomeimprovementstore.rucraftingmaterials.rumodernlighting.ru
Old Aug 25, 2025 | 09:13 AM
The latest post from HaroldsCrimi does not seem to be helpful to diesel truck owners. Even if it was, he is posting to a 21+ year old post.
I am not brave enough to click the link.
Old Aug 26, 2025 | 12:46 PM
edwinsmith's Avatar
I'm not sure but I think this web site is in Russia. BEWARE!
93dieselZak
Jun 16, 2011 06:10 PM
Tron
Jan 3, 2008 11:14 PM
Jordan5687
Aug 19, 2007 01:14 PM
mainer
Jul 17, 2007 07:13 PM
